Quality Weatherstripping Knowledge Needed
Old Jan 27, 2024 | 08:58 AM
JAR3's Avatar
JAR3
Default Quality Weatherstripping Knowledge Needed
All, I need to replace the majority of my weatherstripping. My problem is making sure I spend the money on quality. I dont want to be replacing it in 3 years. So what is better/best - EPDm or Latex? I have looked around and found both are expensive and a full kit seems to run 700+. I don't seem to see Latex for the back window hatch which makes me think if I'm buying EPDm for the hatch why not for all.
I keep thinking latex because it was factory and shouldnt cause adjustment issues you seem to get with cheap sponge weatherstrip. Is EPDM consider quality, cheap, or an improvement to Latex?
Corvette Rubber Co. couldn't do a worse job of selling why but their product other. Aboalutely no content as to why theirs is best to buy. Corvette Central I didn't think is that much better. ZIP, which I associate with economy products, do a good job.
I called Corvette Mike in CA and they quoted $1,150, cant justify on $1,500 barn find.
I need to resolve so i can be ready for spring! All knowledge drips on this post is greatly appreciated.
Old Jan 27, 2024 | 09:17 AM
Dredgeguy's Avatar
Dredgeguy
By far Corvette Rubber is the best quality at a fair price. Others are made in India or China, this is made in the USA. https://corvette-rubber.com/collecti...84-1996?page=1. They are also known as: https://www.mmri-crc.com/
Old Jan 27, 2024 | 01:18 PM
Phobos84's Avatar
Phobos84
I'm in the minority here. But so far I've had good luck with the cheap ebay kit for $100. its not foam at all. Every piece is solid rubber. I know that a lot of people have ordered the cheap kits and had fitment issues. But think about it this way. If you get a complete ebay kit for $100. Lets say out of that kit everything works fine except one or two pieces. Then you can just order those pieces from someone else and save a lot of money. But being the ebay sets are rubber and not foam I can't see how it wouldn't hold up over time. Best part is if everything went wrong and every piece of the ebay kit was of spec you get your money back.
Old Jan 27, 2024 | 07:56 PM
JAR3's Avatar
JAR3
This is the set I have been considering. Did it require any wi dow adjustment to seal well?
Old Jan 27, 2024 | 11:20 PM
AffableCurmudgeon's Avatar
AffableCurmudgeon
Another vote for corvette rubber. I replaced everything other than the hatch last year when I bought the car. CR gaskets worked beautifully.
Old Jan 31, 2024 | 08:18 PM
eawatling's Avatar
eawatling
Not worth it. Please don't go cheap you will end up replacing every piece. Last owner did this one mine and ended up cracking the hard top and having never-ending leaks. Doors require lots of force to close. I've had to buy every new piece from corvette rubber and the quality is night and day.
Old Jan 31, 2024 | 08:38 PM
Phobos84's Avatar
Phobos84
And what did that cost you? Looking at the prices on their site... that's not worth it. I just installed the eBay kit. Other than having to shave a little off the roof panel pieces it worked fine. Corvette Rubber is a rip off.
Old Feb 1, 2024 | 01:59 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
You need to do a post about how it worked for you and what did. maybe you have one already?
my daughter cannot afford the crc stuff. how did you make the cheap stuff work? do you have to slam doors?
Old Feb 1, 2024 | 07:47 AM
solar88's Avatar
solar88
This is exactly what I did, I ordered a cheap $100 eBay kit and ordered the windshield and halo rubber from Corvette Rubber, was able to use both and saved about $300. I found the fitment issue with the cheap kits is the windshield and halo, but the targa top, doors and hatch fit fine with no leaks and seem well made.
Old Feb 1, 2024 | 09:34 AM
Dredgeguy's Avatar
Dredgeguy
With Corvette Rubber everything fit and worked as it should with no issues.
Old Feb 1, 2024 | 10:51 AM
yakmastermax's Avatar
yakmastermax
My only experience is with the rear hatch glass halo sections.
I have had three sets of strip. Two cheap ebay, one corvette rubber. One cheap ebay set fit, but split at the corner seam just from sitting and age.
One ebay set simply did not fit at all. I had to snip out a section to get it to fit. Essentially a worthless waste of money.
The corvette rubber set went right in, fit perfect, and has been good to go for about 2 years daily use now.
Old Feb 1, 2024 | 11:15 AM
eawatling's Avatar
eawatling
The cheap stuff will make you have to slam doors which can chip your paint and breaks stuff. It cracked the fiberglass top on mine when the old owner did it (1000 dollar top). The cheap stuff leaks constantly and will break over a relatively short amount of time. Also good luck closing the doors with the windows rolled all the way up, or even rolling them up all the way while closed. Not worth it. The back hatch also requires slamming to close, and those are fragile pieces of enormous glass
Old Feb 17, 2024 | 08:40 AM
JAR3's Avatar
JAR3
After much consideration I decided to buy a full kit from Corvette Rubber. This car will be sitting out and be an everyday driver. Needs to be water tight. I dont want to do things twice because of quality.
THANKS FOR ALL INPUT.
I think k of how much I got in it and and probably wont make much on the car vs buyi g one in much better condition. The difference is much of the car will be new.
To Quality Weatherstripping Knowledge Needed
