Do I Need To Add LSD Additive ?
Old Jan 28, 2024 | 05:40 PM
solar88's Avatar
solar88
Default Do I Need To Add LSD Additive ?
I have a 88 and hear everywhere I check that when changing the oil on the rear differential you should add the 4oz bottle of AC Delco LSD additive. Though the FSM only mentions the additive for Camaros, and says to use straight 80w-90 for all other applications. I suppose it couldn’t hurt to just add the additive anyways but thought I’d ask here, thanks.
Old Jan 28, 2024 | 05:43 PM
LightningBrett's Avatar
LightningBrett
Some bottles include the additive. Just check the back of the bottle, to make sure. Otherwise add it.
Old Jan 28, 2024 | 05:46 PM
Aardwolf's Avatar
Aardwolf
My cars were totally fine with the LSD in it already and not adding extra. Some could be different give it a try.
Old Jan 28, 2024 | 06:51 PM
dizwiz24's Avatar
dizwiz24
Yes
i seized up my d44 doing a peelout in the rain where one side of the road was slick patching cmpd and the other side was tar/chip
changing the fluid , and adding 2x the amount of posi additive . Then doing a bunch of figure 8 turns in cul de sacs unseized it
Old Jan 28, 2024 | 08:03 PM
solar88's Avatar
solar88
Thanks everyone, just ordered a bottle of the additive.
Old Jan 28, 2024 | 09:16 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by dizwiz24
Yes
I wonder if that is part of your source of slow 60' times.
Old Jan 29, 2024 | 06:21 AM
Phobos84's Avatar
Phobos84
Read the label on the oil very carefully. A lot of modern oil companies include the additive in synthetic gear oil. For example Redline and Amsoil do (or did) but to my knowledge Mobil does not. Doubling up on the oil additive isn't good either. The old rule of thumb was to add two 4 ounce bottles with conventional gear oil. Following this rule with some modern synthetics can cause the LSD to slip and you would do the dreaded one wheel peel. But to add more to the confusion is that the companies that do include it don't put in the same amount. Some use more than others. I feel its a good idea to research it just a little. Do a search on the forum for the brand you like and see what others have said worked for them. I personally used Redline (which has a small amount of limited slip additive already) and I added a 4 oz bottle to that. So far everything seems fine but if I wouldn't have read the label and instead followed the old rule of thumb and put in two 4 ounce bottles of additive I may have had issues. Also if you can, try and add the same brand of additive as the base oil. This will eliminate the possibility of oil incompatibility that can cause foaming and oil break down. I know in today's world that's rare but I've seen it happen in industrial gear boxes a lot over the years. It certainly could happen in your car.
Old Jan 29, 2024 | 07:45 AM
solar88's Avatar
solar88
I know not to use synthetic oil, just using standard STP 80w-90, and pretty sure that stuff doesn’t have additives but I will check just in case. I ordered one 4oz bottle and that’s all I’m adding, thanks for the info.
Old Jan 29, 2024 | 08:13 AM
Phobos84's Avatar
Phobos84
I wouldn't say to not use synthetic oil. I only use synthetic in mine. Just be cautious what additives come in it.
Old Jan 29, 2024 | 07:03 PM
bjankuski's Avatar
bjankuski
Moble also has the additive.
Old Jan 29, 2024 | 07:14 PM
colter's Avatar
colter
You'll actually need two bottles. I went with Valvoline that has the limited slip additive in it and added a bottle of the AC/Delco limited slip additive, and ended up having to add a 2nd bottle of AC/Delco limited slip additive.
Old Jan 30, 2024 | 04:40 PM
solar88's Avatar
solar88
Why do I need 2 bottles ? GM only calls for one 4oz bottle
Old Jan 30, 2024 | 05:02 PM
colter's Avatar
colter
Many have to add two. But you can add one and see if you get any grinding or noise when turning.
Old Jan 30, 2024 | 06:01 PM
JoBy's Avatar
JoBy
The additive is a friction modifier.
If the clutches grab too much they will stick and you will notice most when turning at slow speed.
The clutches will stick, release and stick and turning will not be smooth.
The modifieer reduces friction between clutches. It will at the same time make the LSD looser.
Too much additive and one wheel burnouts are more likley.
I bought the bottle when changing oil, but I did not use it. No problems yet.
Could be that the friction discs were already solked with enough additive from the previous oil.
If the LSD starts binding in the future I will add the additive at that time.
Old Jan 30, 2024 | 06:57 PM
solar88's Avatar
solar88
I have no issues with the rear end, just doing maintenance, so one bottle should be fine. Thanks for the info.
To Do I Need To Add LSD Additive ?
