"Change Oil" light ...how to turn off?
Old 01-26-2003, 09:14 PM
Davevette2003
Davevette2003's Avatar
Default "Change Oil" light ...how to turn off?
My change oil light came on, even though it has only been less than 3,000
miles since I changed it. (Mobil 1) Oil level was fine...but went ahead and changed it anyway. Now, how to get the light to turn off??? :confused:
Old 01-26-2003, 09:39 PM
STL94LT1
STL94LT1's Avatar
Default Re: "Change Oil" light ...how to turn off? (Davevette2003)
1. Turn key to RUN, don't start.
2. Press ENG MET, twice.
3. Within 5 sec press and hold GUAGES until CHANGE OIL light flashes and goes out. When light goes out, monitor is reset.
Old 01-26-2003, 09:42 PM
jimswhite92
jimswhite92's Avatar
From the manual
turn ignition key to on - the engine should not be running
press ENG/MET button on the trip monitor. Then within 5 seconds press and release ENG/MET button again.
Within 5 seconds of the above, press and hold the RANGE button (1991) or the GUAGES button (1992 through 1996.)
The change oil light should flash. Hold the GUAGES or RANGE button until the light stops flashing and goes out.
If you make a mistake during this procedure, turn the ignition off and retry the procedure.
Hope this helps ... Jim
Old 01-26-2003, 09:44 PM
Davevette2003
Default Re: "Change Oil" light ...how to turn off? (STL94LT1)
Thanks guys....will do in the morning. Is there a source for items like this for future reference??? Again, Huge thanks. David :D
Old 01-26-2003, 09:45 PM
STL94LT1
STL94LT1's Avatar
Default Re: "Change Oil" light ...how to turn off? (jimswhite92)
Owner's manual.
Old 01-26-2003, 09:46 PM
jimswhite92
Try TECH section... It's loaded with info. Otherwise, just post it here...
Believe me these people know their stuff ... Valuable resource
Old 01-26-2003, 09:50 PM
Davevette2003
Ok, got off my lazy butt, went out to the garage and did what your guys said. Light is now out, I am very happy...and thank you. David Ames :cheers:
Old 01-26-2003, 09:51 PM
secondchance
secondchance's Avatar
Davevette2003,
It may be that the time before last Oil Change Interval was not reset. Thats probably why the "light came on although its been less than 3000 miles since the last oil change". If you go by miles to change the oil, as I do, just turn the Oil Change light off when it comes on and perfom oil change based on miles.
[Modified by secondchance, 9:53 PM 1/26/2003]
Old 01-26-2003, 10:56 PM
vette_dreamer
vette_dreamer's Avatar
Default Re: "Change Oil" light ...how to turn off? (secondchance)
Doesn't synthetic oil last 7500 miles? Seems like everyone changes oil at 3000 miles, even with mobile 1 synthetic. how come? :confused:
Old 01-27-2003, 12:50 AM
eddieL98
eddieL98's Avatar
this info is not in Tech Tips, can someone please submit the info. this gets asked a lot. i know cause i ask about ever three months...lol but the check engine light comes on by time and mileage, not what type of oil is in there. i asked this question about a week ago :lol:
From the manual
Old 01-27-2003, 06:16 PM
C4kid94
C4kid94's Avatar
Default Re: "Change Oil" light ...how to turn off? (vette_dreamer)
It can last 7500, but its better to change it at 3000 because of the contaminants that can build up. Its just better protection for your car
To "Change Oil" light ...how to turn off?
Quick Reply: "Change Oil" light ...how to turn off?
