Question on Injector Offset Table
I have new injectors with corresponding voltage offset data, however the data I have is far fewer datapoints than what is in the Injector Offset vs Battery Voltage table. So, how do I update the table? I can do the math to find what some of the midpoints should be, but I just don’t know if that is the right way. I get that some of the data points in the table are useless, like everything below 10v and above 16v. Chances are, it’ll never see that voltage. I’m sure the most important and referenced values are something in the 11-15v range.
for a visual, this is the table, that has 32 voltage datapoints.
and this is the V offset data available with the injectors, 8 datapoints.
First off, thank you ULTM8Z. I appreciate the shared knowledge regarding the injectors in this and other posts.
hoping you might take a look at what I came up with as this is my first go around with injector offsets. Highlight is the know values, non highlights what I filled in. Graphed it as well as the stock table. Different curves but I think expected.
