high performance break option???
Old Jan 26, 2003 | 11:58 PM
BowTieBlood's Avatar
BowTieBlood
Default high performance brake option???
If I read my rpo codes and they tell me I have the "high performance" brake upgrade or whatever it says exactly... what does this include?? I'm sure things have been replaced over time, but I'm curious to what the difference is over base model brakes.... :steering:
[Modified by BowTieBlood, 11:14 PM 1/26/2003]
Old Jan 27, 2003 | 12:00 AM
vader86's Avatar
vader86
Default Re: high performance break option??? (BowTieBlood)
Do you mean BRAKES?
J55 is just bigger rotors and slightly bigger calipers.
Old Jan 27, 2003 | 12:05 AM
sraft's Avatar
sraft
If it's the J55 RPO you're referring to, then you have upgraded front rotors/calipers. The rotors are 13" dia. vs. 12" and are also a little thicker. The calipers are wider to accommodate the rotors. The front brake pads are the same.
Old Jan 27, 2003 | 12:14 AM
BowTieBlood
Default Re: high performance break option??? (vader86)
yes............ brakes thank you
Old Jan 27, 2003 | 01:48 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: high performance brake option??? (BowTieBlood)
12" = Crappiest brakes
13" = Crappier brakes
Every brake system GM has put on a car has been crap. Even the C5 stuff.
To high performance break option???
