New engine or upgrade existing engine
thanks, paul
I just finish rebuild my 88 engine with nothing special like you're thinking about and it cost me about that much or more this includes new radiator, new hoses, sensors, alternator, starter, battery, new heads, new pistons, rings, GS brake caliper. Reused cam, crank, piston rods, valve lifters. Haven't rebuild transmission yet. All this cost is only for parts and machine shop charge. I took the engine out, took it apart, put it back together, drop it back in the car myself so there are minimal labor cost. I don't want to count the receipts yet, I would have a heart attack if I add it all up. All the little things that needed from the auto parts store add up to a huge chuck too.
[Modified by VQT88Vette, 10:57 AM 1/27/2003]
[Modified by ejfagala, 4:12 PM 1/27/2003]
I too, used to be concerned about 'matching numbers', but since 1995, no more.
I also thought of purchasing a 'crate motor' or one from Summit, for example.
The more I thought about it, the more I reasoned, that I'd really prefer re-building my original '86 Vette motor.
My reasoning was: I wanted to have fun with the mods, by going through the thought process of what parts I wanted, to bring my engine back to life.
I didn't want an engine already decided for me. If I did it this way, I'd have my stock '86 engine taking up garage space, just waiting for the day that I'd end up selling it, just to get rid of it.
That being said...it's been fun building my own engine over the years, and it has taken years. I try to visualize what any parts mod is going to do for me at the present, and then try to determine how this latest part mod will relate to the next planned mod.
I limit myself to $1500.00 a year for all parts, and labor, if required. Sure, it's a challenge to do it this way, but it serves me well, by limiting my spending...
just to spend. Secondly, I make myself think about "how do I expect this mod to work for me today, and in the future...when I do the next mod."
It's to the point where I really have come to enjoy the motor that I'm presently running. You can see by my signature, that it's not the most powerful, but it is a motor that allows me to compete with nearly everyone.
Since my motor work is done, my next mods will be a 4:10 gear, and in a year or so, a 6 speed. A little bit at a time, works for me.
Good Luck with your decision.
You have to decide two or three things, what is your time frame, what is your goal and how much do you want to spend? I am sure you don’t want to be tinkering with it all the time either once the new engine is in. Also remember that the rule of thumb is 1.0 – 1.2 HP per cubic inch rated at the flywheel. Will you pull the motor or do you want it done turnkey (more money)?
If 375 HP is your goal and you have $6000, buy a 383-crate motor from
http://www.strokermotor.com/377LB.htm
http://www.speedomotive.com
or Diabolical Dave here on the forum and be done with it. Put your 85 motor on a stand in a motor bag and keep it for the future. Then if you find a cheap fixer upper in the future you’ve got a base motor already.
$6000 is ample for a 355 build with your block,,, or a 383 using your stock ported plenum, ASM runners and an ACCELL base and it will look stock. You can use the starter distributor etc from your 85.
If you want to pick the parts and build your own motor, (depending on your level of knowledge) then bone up on EFI’s, and read and study. I knew a lot about the old muscle cars, GTO’s, 442’s, GTX’s etc but EFI is quite different.
I begun my project for the 406 back in September and all I have bought too date as I said are the 400 std engine block, 400 std crank, Hooker headers, BBK-TB and MINIRAM. The most important part which are the heads and cam are pretty close to being decided upon and once that is done, then March should be the target date for my stock 85 motor to be pulled and the new motor to go in.
Good Luck!
[Modified by ld85, 7:02 AM 1/28/2003]
I would purchase a new 400 block and build that. This way you will not have much down time with your Vette.
Vic
Paul
http://www.sdpc2000.com and http://www.sallee-chevrolet.com both have a great selection of crate motors.
The LT1 cars are a great buy now. But if you have solid problem free 85 do you want to step into another 10 year old used car. My 93 was going great with almost 110k miles. Also 90-91 ZR1s can be found under $20k :crazy: Oh the decisions......I know just decided to go with a C5
[Modified by 93Polo, 10:24 PM 1/28/2003]
