Differences Between MAF & MAP Air Cleaner Setup = ???
Old Jan 27, 2003 | 07:45 PM
jmr302's Avatar
jmr302
Default Differences Between MAF & MAP Air Cleaner Setup = ???
Is there any difference between the L98 MAF aircleaner housing and the later L98 MAP aircleaner housing?
I'm swapping to MAP and wanna know if I can keep my old MAF aircleaner housing.
Old Jan 27, 2003 | 08:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Differences Between MAF & MAP Air Cleaner Setup = ??? (jmr302)
Don't know about your year, but my '95 lid fit on my '93 with no problem. The major difference between my '93 and '95 is the air duct going to the TB.
Old Jan 28, 2003 | 10:38 AM
jmrl98's Avatar
jmrl98
I think the housings are the same. You sure you want to go to MAP? Even the General went back to MAF with the LS1. :seeya
Old Jan 28, 2003 | 03:39 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Differences Between MAF & MAP Air Cleaner Setup = ??? (jmrl98)
I bet he is having problems getting the 165 ecm to work well with a built up 383. I have had a problem with a lean miss on tip-in and several chip burnings havn't been able to solve it so I'm now converting to the 727 ecm MAP setup because "experts" have said they can solve this problem.
As for the original question, wasn't there a change made somewhere early '90 when they tipped the radiator back at a angle and came out with a different air cleaner housing to compensate for the angle? To get rid of your MAF you just need to fabricate a 3.5 inch tube to insert in place.
Old Jan 29, 2003 | 01:19 AM
jmr302's Avatar
jmr302
True dat, jmrl98. They actually went back to MAF on the later LT1's using a more reliable MAF unit that works on slightly different principles.
You're pretty much right about the 165 MAF tuning. It would also be nice to not have to worry about MAF failures. I'm not doing the 730 swap, just the 808 conversion to the 165.
So the aircleaner housing changed to fit the new radiator in '90?
Old Jan 29, 2003 | 03:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The air cleaner housing on '90 & '91 MAP L98s was different from that on prior MAF L98s.
However if you can get the '90/'91 bellows to fit between the TB and air filter intake you should have no air filter housing problems after the conversion.
To Differences Between MAF & MAP Air Cleaner Setup = ???
