Ski, that's looking REAL GOOD :eek: ! Don't you just love a clean, fresh motor on the stand, nice and easy to get at everything? You better do something about those blue rags though, they just don't match your color scheme at all :skep:...
Don't forget to post pic with the motor installed in the vette.
It looks really good and I bet it will run just as good too!
That color looks a lot better then the other red you had, did you spray it on there or just brush it, I nead to paint one and I was thinking about getting some paint like, that wont something better then just the spray can.
The paint is a brush on supplied by POR-15 company. Do a search on their name and you will find it. The entire kits cost only 50 bucks, includes everything you will need, from brushes to degreasers. :cheers:
It will look like you dipped it in plastic! :)
As for the details of the buildup:
Super Ram, fully ported (by me ;) )
AFR heads 190 cnc ported. Valve upgrade
K-motion 800 series springs good to .640 lift
Comp Cam solid roller lifters.
Comp cam pro mag 1.6 ratio RR
TPIS solid roller cam 242/242 .610 lift :smash:
Wiesco Forged pistons
Lunati Forged 5.7" Rods
Stock cast crank
400 GM block .030" over cast 11-22-1976, 6PM (from what I can tell) :) 509 series; 2 bolt main
Hooker 1 3/4" model 2151 :D
Moroso pan with trap doors+ extra oil capacity
Vigilante 3200 stall converter
3.07 rear gears (D36 for now) need to get a D44 3.07 ratio in there quick!:yesnod:
58mm Holley TB
MAF gutted :D
Custom Chip (by me! :D )
You have a lot of good parts in your engine, the cam you have it not that far from what I have in my camaro, you have more lift but less durasion...mine is 246/248 but onlie 562/568 lift what center line do you have mine is 110, you must have 112 or more.
