PCV boost question
Old Jan 28, 2003 | 01:14 PM
mn_vette's Avatar
mn_vette
Default PCV boost question
When running boost do you have to block off your PCV(positive crankcase ventilation?) valve to keep the boost from going into the crank case? If so does anyone have any experience doing this on a '93 where the pcv is on the driverside under the fuel rail(or does it have to do with the tube going from the TB to the valve covers?)
Any help would be appreciated. Thanks.
Old Jan 28, 2003 | 03:02 PM
StealDads67's Avatar
StealDads67
Default Re: PCV boost question (mn_vette)
:lolg: What?!? The boost goes into the cylinders..... Why would there be any extra PSI in the crankcase?......
Im guessing this is a joke right
Old Jan 28, 2003 | 03:46 PM
mn_vette's Avatar
mn_vette
Default Re: PCV boost question (StealDads67)
No it's not a joke. The PCV uses the vaccume in the intake to pull the gasses out of the crank case. I'm not sure if there is a problem when the vaccume goes to boost. I don't know the system well enough so I thought I would ask for help.
Old Jan 28, 2003 | 04:04 PM
bill mcdonald's Avatar
bill mcdonald
I think they move the PCV to the turbo intake to suck the pressure up?? or is it the tube that does not have a check valve? (what ever that is called)
But that is a good question.
I hope someone can tell us what is done to all the vacuum lines when adding boost. Do they all need check valves?
[Modified by bill mcdonald, 1:08 PM 1/28/2003]
Old Jan 28, 2003 | 04:11 PM
bill mcdonald
Because the whole manifold gets filled with boost, which travels down all the vacuum lines that connect to the intake. instead of vacuum hoses, they become boost hoses. :lol:
Old Jan 28, 2003 | 04:31 PM
mn_vette's Avatar
mn_vette
Default Re: PCV boost question (bill mcdonald)
Is it ok to just put a valve cover breather on the end of that tube to relieve the pressure and cap off the TB port to keep from loosing boost?
Old Jan 28, 2003 | 04:34 PM
lead foot 85 vet's Avatar
lead foot 85 vet
The installation instructions from ATI on my 85 had me remove all the pvc lines and plug the manifold holes . I now have breather caps on the valve covers. :chevy
Old Jan 28, 2003 | 05:29 PM
StealDads67
Default Re: PCV boost question (lead foot 85 vet)
Ahhh. Sorry I read the question wrong.... my fault :thumbs:
Old Jan 28, 2003 | 09:42 PM
MrNuke's Avatar
MrNuke
I thought replacing the PCV valve on the drivers' side is bad for the engine??
I have put a breather on my passenger side valve cover hole, but the PCV valve was deemed necessary from research and topics I have read on this and other forums. Anyone have any more info on this?
Old Jan 29, 2003 | 12:26 AM
Gold nugget's Avatar
Gold nugget
Yes I have had problems with capping off the crankcase ventilation tube and posted questions in past without reply.When capping tube check engine light comes on.ATI had no cure.Hope some can help.
Old Jan 29, 2003 | 11:21 AM
krivera's Avatar
krivera
Default Re: PCV boost question (Gold nugget)
i agree mine is setup like this------>The installation instructions from ATI on my 85 had me remove all the pvc lines and plug the manifold holes . I now have breather caps on the valve covers.
Also my charger was installed by ATI and that is how they have it done...i have baby breather caps on my valve covers and capped off the intake and throttle body vacuum!
:D
Old Jan 29, 2003 | 01:54 PM
Flame Red's Avatar
Flame Red
I think I have the answer to this. I put a beather on the pass side valve cover and left the PVC connected to the manifold. Plugged the port on the throttle body.
When positive boost is obtained, the PVC valve closes as to not let the boost leak into the crankcase. This is a builtin safety of the PVC system. It is needed when the engine backfires to prevent the backfire getting into the crankcase.
To see that I am correct, take the PVC hose off the manifold and blow into it. Don't forget to have a beer in hand to get rid of all the oil and gas flavor! Or you can use a mitivac if you are faint of heart. If the PVC valve is functioning correctly no air will go into the crankcase. If it does, replace the PVC valve.
You also may have the same concern with the power brake booster. It also has a check valve that will prevent boost from getting in.
The only one I am not sure of is the EGR and Vapor canister.
Old Jan 29, 2003 | 02:52 PM
mn_vette's Avatar
mn_vette
Default Re: PCV boost question (Flame Red)
Ok, so the consensus seems to be disconnect the pipe going from the pass valve cover to the TB, put breather on the valve cover side and plug the TB side. And the PCV valve should do it's job and be ok as is.
Any contradictions???? :confused: If not that's what I'll be doing tonight
Old Jan 29, 2003 | 05:31 PM
krivera's Avatar
krivera
ok wait...i thought you had to get breathers for the valve covers because you dont want all that pressure in the crank case because that pressure has to go some where?
Old Jan 29, 2003 | 11:27 PM
MrNuke's Avatar
MrNuke
Now THAT makes sense. Knew I kept mine conencted for some reason.. :thumbs:
Old Jan 30, 2003 | 10:36 AM
snaketr's Avatar
snaketr
Default Re: PCV boost question (MrNuke)
Mine are disconteccted and I have an evacuation kit installed. It is also a good idea to use a zip tie on the vacuum lines you do have so you do not blow them off. I installed a check valve in the car vacuum so it would not damage lines in my dash and my AFR uses a #4 braided nylon line that has #4 AN connectors so it will not blow off under full boost.
Most kits do not come with it, but it is a good idea to have a blow off valve when you go from wot to closed throttle, that way you do not strain the impeller in the SC.
[Modified by snaketr, 9:37 AM 1/30/2003]
Old Jan 30, 2003 | 11:42 AM
Flame Red's Avatar
Flame Red
Default Re: PCV boost question (krivera)
No, that is not correct. You want a breather there to supply air to the crankcase when the engine is operating with normal vacuum (no boost). so the PVC can suck in the fumes into the manifold.
If you don't have a breather, meaning you leave that connection from the throttle body to the pass side valve cover to supply air for the PVC, the boost will come out of the throttle body and pressurize your crank case. It is best to plug the output of the TB that fed air into the PVC system.
When you cap it off, it is a good idea to wire tie it. I have heard that people with large boost had these caps fly off!
To PCV boost question
Old Jan 30, 2003 | 11:53 AM
mn_vette's Avatar
mn_vette
Ok, on my car there is a tube going from the TB to the pass valve cover. Nothing in the tube, just a tube. The actuall PCV valve is on the drivers side of the intake manifold. But I'm not sure what the two tube on the pcv go to so it's hard to figure out which way the gasses flow, but I'm pretty sure the ones going into the TB get sucked in so boosting it without a check would be bad. I'm just not sure what to do with the other side...
Ok, so you are saying that I need to keep vaccume on that side of the valve cover? something like hooking it up to the airfilter, to keep the gasses flowing out of the crank case? perhaps I would be able to retrofit a second pcv valve in the tube to keep the stuff flowing in the right direction and keep the stock set up like that..........??????hmmmmm, time to think
[Modified by mn_vette, 4:57 PM 1/30/2003]
Old Jan 30, 2003 | 01:45 PM
Flame Red's Avatar
Flame Red
MN,
ok, I'll try to make this clear. On the pass side valve cover put a breather filter. Remove the tube that went from the pass side valve cover to the throttle body. Plug (and wire tie) a cap on the throttle body where this tube went in.
Do nothing to the driver side (where the PVC is).
The manifold sucks (vacuum) from the PVC on the driver's side. The PVC will stop the boost from going into the crank (if the valve is good).
The tube on the pass side supplied air from the TB into the crankcase.
Hope that clears it up.
krivera's Avatar
krivera
ok lets make this simple
1.TB tube on passanger side cap off with wire tie or something
2. valve cover passanger side baby K&N filter
3. valve cover drivers side baby K&N Filter
4. intake manifold cap off with wire tie or something.
purpose to relieve pressure in the crankcase and baby K&N to filter the air? there are some states that need emissions stuff and there is stuff from jegs or summit you can get parts for that emissions
