Need $8D Bin File for Pro Flow XT
Old Mar 24, 2024 | 01:13 PM
Nilak's Avatar
Nilak
Originally Posted by eutu1984
I actually do not use sauip I am to used to the xdf and adx that I use and my brain is getting to old and unflex able so what I do is just copy from the compare
the tables and settings for ae and pe and what not and then go from there.
when you read a v5 with the old xdf some of the varaibles might not be located where the xdf thinks they are and could return a value that is not what it was supposed to be, but if what you read makes sense then it is probably correct.
Old Mar 24, 2024 | 01:49 PM
ULTM8Z's Avatar
ULTM8Z
you are now if you're running the Miniram start bin...lol
Old Mar 24, 2024 | 04:48 PM
Nilak's Avatar
Nilak
I understand he is not using a v5 bin but his own bin and compared it to a v5 for miniram on the original aujp xdf. some variables may show up with corrupted values ideally you want to open the v5 bin with a saujp v5 and copy what you need in an excel table or txt file then check the settings. However, you need to be careful on conversions because for example the PE MAP threshold in stock bin and aujp is 90 but in V5 it will show you 10 because it’s converted to vacuum while the hex value is identical.
There is a good chance what was copied was ok especially if the values looked alright.
Old Mar 24, 2024 | 07:30 PM
ULTM8Z's Avatar
ULTM8Z
I had sent him my Miniram start bin earlier. It's based on SAUJP v5. So basically if he's using that bin, he's using SAUJP.
