Engine running rough
Old Mar 18, 2024 | 09:32 PM
Thepersian's Avatar
Thepersian
Default Engine running rough
Hi folks,
I'm going to share as much detail as possible about the issue in case someone on the forum has had a similar experience and can provide some guidance.
I have a '96 LT4 and a couple of days ago as I got home and parked in the garage, I started feeling an unusually strong vibration from the engine. The vibration is rhythmic with the RPM, it's not sporadic, and it's not a hum, buzz, or drone.
I drove it around the block the next day, still had the same excessive vibration at low RPM, and hesitated and sputtered in acceleration, with the power surging and dropping sporadically.
When cold, the idle is rough and the RPM keeps fluctuating ever so slightly, almost as if the engine keeps trying to correct itself but falls down again.
And strangely, there are NO CODES (yet)!
UPDATE: CODE P0300
I'm going to go through a list of potential culprits:
1. The MAP sensor: I cleaned up and put it back in, but no luck (also broke the connector into pieces so will be replacing that)
2. A vacuum leak: I'll test the vacuum lines to see if there's any leaks anywhere. Visually, none of the rubber looks disastrously dry or breaking.
3. Fuel injectors: Been wanting to replace the fuel injectors for a while, and this seems like a good opportunity to get it done.
4. Alternator: Maybe unlikely that the alternator is the cause of the issue, but I have always had a very slight fluctuation in the instrument cluster's back light. I just always chalked it up to it being an old car!
5. Optispark: I know that the 1995/1996 cars aren't supposed to have optispark issues (or not as much) but I'm guessing if all else fails, that might be worth a look, too.
Fuel filter and spark plugs were replaced about 3k miles ago.
If anyone has had experience with a similar issue, or can help provide guidance in general before I dive in, it would be highly appreciated.
Thank y'all in advance!
Old Mar 19, 2024 | 11:11 AM
dburgjohn's Avatar
dburgjohn
have you checked the fuel pressure. I had a pump fail but not all at once. It would loose pressure and regain it randomly. Then engine behaved very much like you describe. I did not catch it at first because I was used to pump failures that stayed failed not wandering in and out of spec. I would also suggest checking the connectors on the ignition parts to ensure no bad connections. Good luck in your search.
Old Mar 20, 2024 | 06:42 PM
Thepersian's Avatar
Thepersian
Thanks! I'll check the fuel pressure ASAP.
When looking at the connections, any particular signs of wear I should look out for?
Old Mar 20, 2024 | 10:10 PM
socal_tom's Avatar
socal_tom
The fuel filter could be dirty not letting it get all the fuel or maybe even a pinched line
Old Mar 21, 2024 | 04:01 PM
Thepersian's Avatar
Thepersian
Fuel filter was (supposedly) replaced about 3K miles ago by Corvette Specialists in San Dimas, CA. So I wouldn't imagine that would be the source of the problem.
Old Mar 21, 2024 | 04:03 PM
Thepersian's Avatar
Thepersian
Fuel pressure gauge reads only about 15 PSI with the key in the on position. So that's definitely a problem.
Old Mar 30, 2024 | 10:02 PM
Thepersian's Avatar
Thepersian
Update:
Replaced the fuel pump, and while the car runs slightly better with the new pump and has better throttle response, it's still running rough. It idles with excessive vibration, has loss and surges of power in mild acceleration, and the exhaust fumes have a burnt smell to them. I'm about at the limit of my knowledge with this issue. Might replace the fuel injectors as well, since I already bought a set. But otherwise, I think I might have to take it to a shop for a (hopefully) more accurate diagnosis.
Old Mar 31, 2024 | 08:22 AM
randallsteel's Avatar
randallsteel
Does it have issues the moment you fire it up? Or does it run fine when cold and as it warms up the issues develop?
the reason I’m asking is that i recently had some issues, but it ran fine cold(open loop) and when it warmed up, it switched to closed loop which is when I had issues. This cued me into that it was a sensor fault.
have you double checked spark plug wiring? Ensured that no wire is incidentally against the exhaust manifold?
your description sounds like it actually has a miss. You could pull plugs and see if you could find the offending cylinder(s)
Old Apr 2, 2024 | 08:32 PM
Thepersian's Avatar
Thepersian
It runs poorly from the moment it fires up. The spark plug wires look fine to my untrained eye. The plugs were replaced by a Corvette shop in San Dimas a few months ago. That's why I've never suspected them.
To Engine running rough
