Differences between 94 & 96 ZF6
Old Jan 28, 2003 | 06:05 PM
Vvcdde's Avatar
Vvcdde
Default Differences between 94 & 96 ZF6
Over in the forsale section someone is selling a 94 ZF6, I currently have a 96ZF6 in my car but it is in need of a rebuild. What are the differences, if any?
Old Jan 28, 2003 | 06:12 PM
Chief Muktar's Avatar
Chief Muktar
Default Re: Differences between 94 & 96 ZF6 (Vvcdde)
From 94-96 the only change was in the shifter. They went to a non-lockout shifter in 95/96 (can't remeber which one). Thats about it as far as I know.
Old Jan 28, 2003 | 06:17 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Differences between 94 & 96 ZF6 (Chief Muktar)
I thought they went to the non-lockout in '94. The tranny itself should have no differences.
Old Jan 28, 2003 | 06:23 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: Differences between 94 & 96 ZF6 (Vette92)
My understanding (and I just retrofitted a '96 into my '87 so I've looked recently) is that the '89-'94s had the pull-up collar on the shifter to get into reverse and the '95/'96 had the crash-through shifter. Similar to a non-lockout, though you do have to put ~15lbs (from the specs, not by my SOTP feel) of effort into the shifter to "crash through" the gate.
Old Jan 28, 2003 | 08:05 PM
Skant's Avatar
Skant
Default Re: Differences between 94 & 96 ZF6 (CorvetteZ51Racer)
So that's why it feels like it doesn't want to go into reverse? You're supposed to pull on it hard? I thought mine was just worn out or something.
- Skant
To Differences between 94 & 96 ZF6
