My digital speedometer and odometer does not function properly..the range does not work...my Tachometer and gas gage works ...
Whats the fix?
Thanks for your input.
Bob
Whats the fix?
Bob
You can also just get a $20 gps speedometer until you find your problem. I have that on my 84 plus I have an hour meter under the hood to keep track of engine use.
It could be as simple as a broken VSS ( Vehicle Speed Sensor ) on the transmission.
A simple test would ne to connect another VSS to the cable an run it with a cordless drill. If speedo works then it is the VSS sensor or the plastic gears that drive it from the output shaft of the transmission.
