Desktop Dyno Software
Old Mar 29, 2024 | 09:59 AM
TheKodiak's Avatar
TheKodiak
Default Desktop Dyno Software
Hello Gents, I got some software to play around with, Desktop dyno and drag. In the program, it asks for Cam IVO, IVC, EVO,EVC. Along with Valve Lash and Lift at Valve, numbers. Anyone have any idea what the stock values are? I believe to have exhausted my internet searches to dead ends lol.Thanks!
Old Mar 29, 2024 | 11:06 AM
rklessdriver's Avatar
rklessdriver
IF you can find the factory published spec for the factory cam you are using - duration and lobe centerlines.... You can input them to this calculator and find the timing events.
http://www.wallaceracing.com/cam-deg-calc.php
Also be aware of what your Desk top Dyno software is asking for... is it asking for timing events calculated from advertised or 0.050 lobe numbers? Make sure you use the proper duration to calculate your timing events.
R/S
Will
Old Mar 29, 2024 | 07:51 PM
TheKodiak's Avatar
TheKodiak
R/S
Will
Thank you, the events are calculated using 0.050
Old Mar 29, 2024 | 07:56 PM
mike1111's Avatar
mike1111
what year?
Old Apr 2, 2024 | 06:28 PM
TheKodiak's Avatar
TheKodiak
Its on a 1996 Corvette LT1. I'm just messing around with it to see how "true" it is. I just need the intake center line for the said cam.
Originally Posted by mike1111
what year?
Old Apr 3, 2024 | 01:31 PM
AZSP33D's Avatar
AZSP33D
Typically this is measured with the cam installed and a degree wheel.
I see why the information is difficult to find: there's no cam card with the OEM cam, so people don't seem to time the cams so much on OEM setup, and there were differences in model years and applications. People who knew the Gen 2 LT1 inside and out are mostly gone/retired and not engaged in making information available for everyone.
Here's a link to the cam specs if you can resolve the file to show the numbers properly:
https://www.corvetteactioncenter.com...print-524.html
Old Apr 4, 2024 | 04:40 PM
rklessdriver
117 same as the lobe seperation. GM didn't grind any advance into the cams.
Will
Old Apr 5, 2024 | 12:54 AM
mike1111's Avatar
mike1111
melling stock replacement is MC1336. melling site says 117 centerline for intake and exhaust.
so there's no advance ground into it.
To Desktop Dyno Software
