1993 Corvette suspension recommendations
Old Mar 30, 2024 | 05:18 PM
AmoriFati's Avatar
AmoriFati
Default 1993 Corvette suspension recommendations
I currently have this suspension. 1991 Z07 - FHB 115.5/659 and NYU 57.2/326 with front/rear sway bars as follows 30mm/26mm. I also have ZR1 sized tires front and rear.
I am wondering if the rear sway bar is too big? Some old threads said it would jack the car, but that was with different sized tires. Not sure if that makes a difference.
And will Bilstein B8 ( 89-94 versions ZIP sells) shocks work well with this. Not a race/track car at all. But , I do like to drive the curves a little aggressively.
Old Apr 1, 2024 | 12:24 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If You search the forum you will find there are other shock options than the Bilstein's As far as sway bars go what you have should work well. Your at the point of pushing the car into a slide and letting us know which end lets loose first.
Old Apr 1, 2024 | 10:21 AM
AmoriFati's Avatar
AmoriFati
^ Thnx.
I thin all ZR1s came with the bigger rear sway bar, to help induce oversteer.
To 1993 Corvette suspension recommendations
