Good day to my Corvette family. I have just bought my first Corvette in September of 23 and from the beginning it has had a rough idol. Not to the point where it shuts off definitely notice a mess after it has been driven for a bit and is up to temp.. . I have read on some other LT1 posts and I have already replaced..
1. EGR valve
2. Spark plugs
3.02 sensors bank 1 both sides
4. IAC
5 Mass airflow
6 fuel injectors
7. Spark plug wires
8.ICM cleaned and put new grease as it was dry as a bone.. now it is still doing it .. I love this car and has only 60,000 miles so I want to keep it for as long as I can.. any other idea that would cause this.. it will run like a cat on fire when you put the foot to the floor just idles bad .
I'm wondering if a previous owner may have replaced the camshaft with something a bit hotter than stock. What you're describing sounds exactly like what my 96 with a GM Hot Cam does. In my case it's not actually a miss but rather a mild cam lope. On a cold start it's fairly smooth but once warmed up you can definitely feel that cam lope at idle. Your description of it running like a cat on fire also sounds about right for a cammed car. Unfortunately I don't know of an easy way to tell for sure if a car is cammed, maybe someone more knowledgeable on that aspect could chime in. The only way I can think of would be to pop a valve cover and use a dial indicator to measure the lift on the rocker arms as you manually rotate the engine. What I'm not sure of on this is if the lifters may compress a bit and give false measurements.
The guy I got the car from had it for 3 1/2 years and put 3200 miles total . he bought from a dealership. The motor doesn't look like it's been worked on. He had new tires and exhaust tips put on just before I bought it.. I'm the guy that likes to work on cars as what I have already done. Doesn't sound like a cam change
You didn’t say, but that car is ODB II compliant. Connect a good reader and see if you have any codes saved.
I have a cheap one from AutoZone that all it will say is O2 bank 1-2 lean I have already replaced the 02 sensors twice. What is a good cheap OBD2 scanner that can actually read a specific miss fire on a cylinder. That's is under $100
OK the lean codes are a huge clue. Probably a vacuum or intake air leak. Intake manifold gaskets ? That was my issue to a similar problem. Throttle body gasket ? Vac hoses all good?
If you can’t hook up a vacuum gauge to check your idle vacuum in inches of mercury, with the car at idle get a propane torch and turn it on, don’t light it and pass it around all of your vacuum lines/manifold gaskets etc. If the idle RPMs increase you found the area of your vacuum leak.
