Re: Clutch compatibilty questions
Old Jan 29, 2003 | 09:50 PM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Clutch compatibilty questions
I found someone with a New clutch and flywheel I might want to buy. The parts were ordered for a 96LT4 from McLeod. I'm wondering if I can bolt them on to my L98 engine and march on?
My engine is internaly 0/balanced and the transmission is a ZF. Are there any issues to watch out for?
KM
Old Jan 30, 2003 | 11:39 AM
Red Rocket's Avatar
Red Rocket
Default Re: Clutch compatibilty questions (88-406)
Alot of guys buy the Mcleod with the SMF approach. Check the numbers and make sure its for the Corvette DMF.
Old Jan 30, 2003 | 11:52 AM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: Clutch compatibilty questions (Red Rocket)
I'll certainly check the part#'s when I get them. But it would seem to me that as long as they were ordered as a set flywheel/clutch, I should be able to bolt them right up.
Do you know what the differences where between an L98 & LT4 as far as flywheels or clutches go? Assume both cars have a ZF installed.
KM
Old Jan 30, 2003 | 01:25 PM
T1Kilr's Avatar
T1Kilr
I dunno for absolute certain but I believe there is a difference in the diameter of the input shafts for the 89-93 and for 93L-96 . If memory serves me correctly, the change took place at the time the HP ratings for the trans changed (gear teeth design) ZFDoc.com should be able to answer for certain.
:cheers:
Old Jan 30, 2003 | 01:28 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: Clutch compatibilty questions (T1Kilr)
:iagree:
To Re: Clutch compatibilty questions
