Heater Blower motor problem
Old Jan 30, 2003 | 01:53 AM
vettewally's Avatar
vettewally
Default Heater Blower motor problem
88 vette heat and A/C only seem to work on low.Changed the blower motor but it did not help.What should I check for next? THANKS
Old Jan 30, 2003 | 03:06 AM
C490Vette's Avatar
C490Vette
Default Re: Heater Blower motor problem (vettewally)
I read in another post that you can get error codes from your temp. controls by turning the key to "on" but not start the car, press and hold the fan up and fan down buttons until the temp display shows 00 (about 5 sec.), and then press the auto fan button. After that, any numbers shown are error codes. I used this trick on my 90 to discover I had a low freon level with my A/C. If it works for you and you get an error code, come on back and post the results and I am sure someone here will be able to tell you what it means. I only know 09 is low freon so unless you get that code I cant help you any longer. I am not sure what kind of temp controls an 88 has but if its like the 90, good luck!
:seeya
Let me know if it works! :)
[Modified by C490Vette, 12:06 AM 1/30/2003]
Old Jan 30, 2003 | 08:44 AM
PTz-92-LT1's Avatar
PTz-92-LT1
http://www.idavette.net/tech/c4diag.htm
Old Jan 30, 2003 | 08:51 AM
trupp's Avatar
trupp
There is a resistor network, don't know the proper name, that mounts on the AC housing in the engine compartment. This network is what sets the speeds for your blower motor. With age and use these resistors, actually they are different lengths of coiled metal, burnout. It is really easy to change, there will be one electrical connection and two screws to remove to get the part out and the reverse to install. By the way don't touch the coils with your hands, if you do clean them with a lint free rag and alcohol.
To Heater Blower motor problem
