no reverse lights
Old May 3, 2024 | 05:56 PM
Dave Witman's Avatar
Dave Witman
Default no reverse lights
Have no reverse lights on a 89. Have power and switch works. I look inside switch hole and there is no movrment of plunger when shifting in and out of reverse. Is this a common zf problem.
Old May 3, 2024 | 06:00 PM
s carter's Avatar
s carter
Very common, I bet if you jumped both sides of plug under car lights will work
Old May 3, 2024 | 06:24 PM
Dave Witman
yes they do and so does switch when i push ball with thumb but there is no movement inside trans to acuate switch.
Old May 3, 2024 | 06:48 PM
SirReal63's Avatar
SirReal63
I have this same issue on my 89. I bypassed the ball switch and added a remote switch inside so I can turn on the backup lights and camera at will. It is not the perfect solution but it is a solution. I keep hoping someone will have an easy fix that does not involve removing the ZF6 but so far I have not found one.
Old May 4, 2024 | 05:31 PM
Dave Witman
Thanks i may have to do the same thing
To no reverse lights
