best sensors to replace with new engine
Old May 31, 2024 | 05:08 PM
chagger32's Avatar
chagger32
Default best sensors to replace with new engine
what sensors should i replace? i am dropping in a rebuilt engine for a 95 corvette.
Thank you!
Old May 31, 2024 | 07:14 PM
Topduarte's Avatar
Topduarte
All sensors imo.
Old May 31, 2024 | 08:12 PM
chagger32's Avatar
chagger32
so all 3 o2 sensors , maf sensor , knock sensor , oil pressure sensor , oil level sensor am i missing stuff ? lol
Old May 31, 2024 | 10:15 PM
dizwiz24's Avatar
dizwiz24
I disagree
you have proven known sensors that work vs todays made-in-china sensors.
why throw in another variable (than the engine swap) ?
Old May 31, 2024 | 11:15 PM
auburn2's Avatar
auburn2
Thank you!
I am of the mind that you do not replace sensors that are working.
Also solid-state electronics generally have a constant failure rate and mean time between failure regardless of age. They do not degrade gracefully over time. The electronics in an old sensor that have not failed yet are likely to last as long as a brand new sensor of the same quality. If the older sensor is of higher quality the electronics will likely last longer than a brand new one.
Old Jun 1, 2024 | 11:02 AM
Corvette_Dez's Avatar
Corvette_Dez
Everything that's on the engine and/or hard to get to after the engine is installed. Use ACDelco or Standard Motor Products parts and you'll be very happy.
To best sensors to replace with new engine
