Help me please my a.c does not work
Old Jun 5, 2024 | 11:53 PM
BubbasCorvette's Avatar
BubbasCorvette
1st Gear
Default Help me please my a.c does not work
Please help me. I bought a 89 c4 last year (car is converted to accept normal/new a.c fluid) and the ac at the time worked but stayed on even when you turn the car off so basically if you wanted it off you would have to unplug the cables from the "Blower control module". I looked it up and some guy on YouTube (I'll link the video at the end) said I need a new blower control module so I bought one, installed it and now I get NO AIR AT ALL. Please help me it's so hot outside
YouTube video I watched: https://youtu.be/ WT5u2LwhXhI?si=QCu7sJWzPEMxHGfq
Old Jun 6, 2024 | 06:55 AM
2011KLR's Avatar
2011KLR
Does NO AIR AT ALL mean no air flow a.k.a. the blower isnt turning at all OR is there airflow but it isnt cool air?
Old Jun 6, 2024 | 07:15 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Tack the old blower control module back in, if it blows, you may possibly have two bad blower control modules.
Old Jun 6, 2024 | 08:16 PM
RWDsmoke's Avatar
RWDsmoke
Make sure you have the correct module. The 86-89 module is internally different than the 90-92 module. They look the same and will plug in but the compressor will not run if you install a later module in an early car. The compressor relay is not installed in the later modules. I spent many hours troubleshooting my compressor problem before I discoverd this. Some sellers incorrectly list them as the same.
To Help me please my a.c does not work
