Degrading idle
Old Jun 18, 2024 | 12:16 PM
cds1's Avatar
cds1
Default Degrading idle
I've been chasing a degrading idle on my 95 LT1 for a few years now... and could use some new ideas. An example of the idle degradation is when stopped at stoplight. It idles very nicely for 15-30 seconds. Then what seems like a misfire occurs. The longer I sit at the light, the more frequent the misses become. The problem is more pronounced in gear, but also happens in neutral. This issue has follow the engine through a rebuild, new optispark, plugs, wires, coil, injectors, fuel pressure regulator, fuel filter, fuel pump, etc. No lights or anything in scans. Aside from the idle issue, that engine runs fantastic which is why I more focused on solving this idle degradation now.
Any suggestions?
Old Jun 18, 2024 | 08:56 PM
drive it's Avatar
drive it
Get a scan tool or software with live data. Watching live data while it happens is sometimes the only way to figure out intermittant problems.
Old Jun 19, 2024 | 09:05 AM
Yonker's Avatar
Yonker
I agree with Drive It. But have you checked your IAC?
Old Jun 19, 2024 | 11:33 AM
cds1's Avatar
cds1
Good idea. I have DataCat, and its never dawned on me to use it while the idle is bad.
Old Jun 19, 2024 | 11:34 AM
cds1's Avatar
cds1
I haven't checked the IAC. I've been pretty convinced its an ignition issue, but I'll certain keep the IAC in mind.
To Degrading idle
