Tips for installing Dewitt’s Radiator
Old Jul 6, 2024 | 03:54 PM
Hawkeye56's Avatar
Hawkeye56
I just received the new radiator. Peeking in through the open box the quality looks top notch.
I am slowly gathering up all the hoses. For the install this fall.
Hawkeye56
Old Jul 6, 2024 | 05:51 PM
Whaleman's Avatar
Whaleman
Hawkeye56
I had a feeling you would say that. Are you really saying you just peeked at it and did not pull it out to look? I could never do that. I would just have to look at it naked and out of the box. Dan
Old Jul 6, 2024 | 06:57 PM
Hawkeye56's Avatar
Hawkeye56
I opened the box and removed the packing.
I could get a good look lol.
Hawkeye56
Old Jul 8, 2024 | 01:58 PM
s346k's Avatar
s346k
i can never just look at parts either
Old Jul 9, 2024 | 07:31 PM
Hawkeye56's Avatar
Hawkeye56
Looks like you have quite the project going .
Old Jul 15, 2024 | 09:58 AM
dburgjohn's Avatar
dburgjohn
Default Parts Source?
Where did you find the longer screws?
Hey fellow Hawk, It is easy. You have to jack the car up but they are very easy to get to. You will fight the 3 small screws on the shroud way more. Just remember to put the 3 screws on each side of the shroud back in opposite way they came out. Attached are photos of both the top and bottom with the spacer bar installed. I had to go get longer screws for these. Dan
Old Jul 15, 2024 | 12:00 PM
Whaleman's Avatar
Whaleman
I found them at the local Ace Hardware. If you have a Fastenal near by they would have them also. Dan
Old Jul 16, 2024 | 11:57 AM
dburgjohn's Avatar
dburgjohn
Default bolt size for use with spacer
ok so it looks like the OE screws were M6-1.0 25mm and what you need is a M6-1.0 30mm or M6-1.0 35mm. I did not find any when the unremovable washer like OE, but washers are cheep.
Old Jul 16, 2024 | 03:51 PM
Whaleman's Avatar
Whaleman
Oh, I should have been more clear. I never found any with the unremovable washer. Just the right size with a washer. Dan
Old Jul 20, 2024 | 05:10 PM
dburgjohn's Avatar
dburgjohn
I had to trim the housing around the trans cooler line also. Hole saw, hack saw and a little filing and all was good. The DeWitts tranny line connector is lower than the factory one.
