1994 M6 corvette
Old Jul 10, 2024 | 11:26 AM
Ayjoki's Avatar
Ayjoki
Default 1994 M6 corvette
My 94 has 128,000 miles, It needs a transmission fluid change. What is the best fluid for a ZF 6 speed trans?
Old Jul 10, 2024 | 11:32 AM
WVZR-1's Avatar
WVZR-1
Is there a 'BEST'?
There are preferences and a search will get you better than 1000 threads discussing/asking just what you did!
Old Jul 10, 2024 | 11:38 AM
Rush91's Avatar
Rush91
Subjective for sure, but this is what I put in my '91 ZR-1
Old Jul 10, 2024 | 12:29 PM
Ayjoki's Avatar
Ayjoki
Originally Posted by WVZR-1
Is there a 'BEST'?
understandable though most I seen were outdated
Old Jul 10, 2024 | 12:30 PM
Ayjoki's Avatar
Ayjoki
thank you
Old Jul 10, 2024 | 01:44 PM
WVZR-1's Avatar
WVZR-1
At 128K I might be more concerned with a couple other things, 1.) How removeable are the drain and fill plugs & 2.) should I consider a change and a short 1 or 2K mile for a flush of sorts. If you did or thought you'd like to do the drive/flush maybe the suggested in post #3 is maybe for the 'final' and not the first. Choice might also depend upon your relationship with various vendors if $$$ matter,
If you know or suspect yours will be it's 1st I believe you buy 2 replacement plugs before anything and consider a 1 or 2K mile drive and then maybe repeat. If you knew it had been serviced previously maybe when, at what miles might and brand used might be good to know.
A VW drain plug will work for replacements. VW part # WHT-001-937 but you need to be sure you ask for M17 Hex, they likely offer still a 'spline' drive used much later. Plugs should be available 'locally'.
Old Jul 10, 2024 | 09:56 PM
Siveck's Avatar
Siveck
GM synchromesh was original and is what I’ve been using. Good enough for me as long as it’s available. I remember when everyone seemed to be convinced that BMW motor oil was the thing. 😳
Old Jul 10, 2024 | 10:07 PM
WVZR-1's Avatar
WVZR-1
That's 'wrong'!
Old Jul 10, 2024 | 10:12 PM
Siveck's Avatar
Siveck
That's 'wrong'!
Okay, chill. What was original?
Old Jul 10, 2024 | 10:44 PM
WVZR-1's Avatar
WVZR-1
What's with the chill?
5W-30 GM 1052931 was the original service fluid and NOT until several years after end of production, when GM introduced the product you mentioned it was never approved for service until many years later.
If you use the GM 1052931 and conversions you'll find several products. Royal Purple comes to mind as suggested HPS or XPR 5W-30. Maybe later than 2005 or so GM actually began to acknowledge their 12345349 would be acceptable. That product now would likely be 88900333. Many use the product you use. BUT it was NEVER ORIGINAL> NEVER! I still have some 1052931.
Old Jul 10, 2024 | 10:57 PM
Siveck's Avatar
Siveck
Okay. Thank you for the information. Did not realize that GM synchromesh was not original. Will consult my FSM before making false statements about world ending transmission fluid decisions.
Old Jul 11, 2024 | 05:29 AM
BMH95's Avatar
BMH95
Lightweight shockproof was in mine when I got it and was good. It came out blue Smurf-blood colored.
I used the AMSOil synchromesh this this year. The AMS Oil seems good so far.
Old Jul 11, 2024 | 09:24 AM
Ayjoki's Avatar
Ayjoki
That's 'wrong'!
Would gym sycromesh be good? Or is the amsoil “better” which is subjective but which makes it last longer, feel better etc… and is there anything that I can get today from autopart store or other store?
Old Jul 11, 2024 | 09:26 AM
Ayjoki's Avatar
Ayjoki
regular royal purple 5w30 oil? Scratch that. Is HPS or XPR more equipped for the ZF? I can get HPS from napa
Old Jul 11, 2024 | 10:58 AM
WVZR-1's Avatar
WVZR-1
If you have a relationship with NAPA you might consider maybe Royal Purple Synchromax that replaces the GM #12345349. There's many quality products available. Do your own research.
Old Jul 11, 2024 | 12:52 PM
Ayjoki's Avatar
Ayjoki
I have, seems that Royal Purple Synchromax is too thin compared to amsoil and gm. Has any here used vavoline synchromesh?
Old Jul 11, 2024 | 02:36 PM
Elduderino's Avatar
Elduderino
Good question, Valvoline is all I can find locally, anyone with any knowledge of it??
To 1994 M6 corvette
Old Jul 11, 2024 | 04:47 PM
Ayjoki's Avatar
Ayjoki
The back of it states it meets or exceed 12345349 so I’m giving it a try.
Old Jul 11, 2024 | 06:42 PM
Faceman89's Avatar
Faceman89
I just went through this myself. Ended up going with Amsoil Syncromesh. Shifts just fine.
Old Jul 12, 2024 | 08:46 AM
Elduderino's Avatar
Elduderino
I see there is a product a reputable Corvette aftermarket company sells that is called BG Snycroshift and is 75W-80. The original oil was 5W-30. The only product I can find locally is Valvoline Syncromesh but the bottle does not say the weight. Does anyone know the weight of the Amsoil or the GM Syncromesh?
