Oil pressure gauge question
Old Jul 11, 2024 | 06:49 PM
Brandon Koller's Avatar
Brandon Koller
Default Oil pressure gauge question
Hey y’all I have a 91 l98
Whenever I turn my key to the on position my oil pressure gauge maxes out but all of the other gauges drop to their lowest spots besides the battery gauge of course. So my question is is this normal for the oil pressure gauge? I'm just concerned that maybe there’s a sensor that’s going bad and when the cars running I’m getting an inaccurate oil pressure reading.
thanks in advance
Old Jul 12, 2024 | 07:36 AM
FostersPerformance's Avatar
FostersPerformance
If a sender is grounded out the gauge will peg.
Old Jul 12, 2024 | 10:48 AM
Brandon Koller
If the sensor is grounded will it constantly peg to the max or will it read different values when the car is running?
Old Jul 12, 2024 | 11:38 AM
vader86's Avatar
vader86
If the sending unit connector is bad/loose/frayed, it will read to 80 always.
You should replace the unit and check the connector itself.
To Oil pressure gauge question
