1994 C4 problems and codes
Old Jul 12, 2024 | 09:20 AM
Ayjoki's Avatar
Ayjoki
Default 1994 C4 problems and codes
My 94’s speedometer read 0 and doesn’t change as well as the odometer not moving from current mileage. Getting codes H24 H59 H73 H82 H83 H90
DTC 24 – Vehicle Speed Sensor (VSS) Circuit
DTC 59 – Transmission Fluid Temperature (TFT) Sensor Circuit High (Low Temperature Indicated)
DTC 73 – Pressure Control Solenoid (PCS) Circuit (Current Error)
DTC 82 – Transmission 1-2 Shift Solenoid Circuit
DTC 83 – TCC PWM Solenoid Circuit Fault
DTC 90 – Transmission TCC Solenoid Circuit
I know they have an H for history but I cleared them and these ones came right back. If anyone has any possible solutions and or where these components are and what the ohms should be I’d be very grateful.
Old Jul 12, 2024 | 11:31 AM
OneRedVette's Avatar
OneRedVette
You need to inspect the harness going to the transmission. I'm unsure if there is a fuse powering transmission components, but its worth taking a look at your fuse boxes.
Old Jul 18, 2024 | 09:28 AM
Ayjoki's Avatar
Ayjoki
Originally Posted by OneRedVette
You need to inspect the harness going to the transmission. I'm unsure if there is a fuse powering transmission components, but it’s worth taking a look at your fuse boxes.
Ok will do but should my zf6 manual transmission even have these sensors? Isn’t the tcc solenoid for an automatic?
Old Jul 18, 2024 | 09:32 AM
OneRedVette
Well that would've been very useful information to have.
Sounds like it thinks it's an automatic... Has the computer be replaced, tampered with, or tuned?
Old Jul 18, 2024 | 10:32 AM
Ayjoki's Avatar
Ayjoki
ah yes I’m sorry I wrote in another post it was a manual but it slipped my mind to add it to this one. I just recently got this car less then a week ago so I am not sure but I was thinking that was a possibility. My speedometer shows 0 and doesn’t change nor does my odometer count.
Old Jul 19, 2024 | 07:35 AM
jmgtp's Avatar
jmgtp
Sounds like the PCM, for some reason, has a bin (the “programming”) for an automatic. Probably replaced at some point in the past with a junkyard unit. If you have a Windows laptop and invest in a <$100 cable you can reflash it easily yourself with free software - that is presuming the rest of the engine is stock, if it’s modded then tuning for those mods gets a bit more complicated.
Old Jul 19, 2024 | 07:56 AM
Ayjoki's Avatar
Ayjoki
I made my own cable for my old 95 Camaro that had a obd1 brain and obd2 port is that the cable I need? Or something else?
Old Jul 19, 2024 | 07:58 AM
jmgtp's Avatar
jmgtp
Should be the same. eeHack and Flashhack are the software tools you’ll want
Old Jul 19, 2024 | 09:24 AM
Ayjoki's Avatar
Ayjoki
ok thank you, where do I get the stock tune/file for 1994 manual?
Old Jul 19, 2024 | 09:44 AM
jmgtp's Avatar
jmgtp
I fired up my tuning PC and searched but couldn’t find a stock bin for 94. I’m sure someone on the forum will have one they can send you.
Old Jul 19, 2024 | 11:00 AM
Ayjoki's Avatar
Ayjoki
Ok I make a post for that but do you know why the speedometer with 0 with a code 24? From what I’ve seen is the ecm not seeing the vss signal
Old Jul 19, 2024 | 11:01 AM
FrankieD's Avatar
FrankieD
BINS can be found here:
https://ecmhack.com/tutorials/bin-files/
Old Jul 19, 2024 | 11:22 AM
jmgtp's Avatar
jmgtp
I’d start with validating you have the right bin before digging in on codes/speedo. Might be related, I don’t know if the VSS for auto is different, it’s probably expecting different counts at minimum. The right bin might resolve it.
Old Jul 19, 2024 | 12:30 PM
Ayjoki's Avatar
Ayjoki
Originally Posted by FrankieD
Thank you I appreciate it
Old Jul 19, 2024 | 12:31 PM
Ayjoki's Avatar
Ayjoki
that is very true with the gear ratio being different, do I need both eeHack and Flashhack?
Old Jul 19, 2024 | 01:35 PM
FrankieD's Avatar
FrankieD
EEHack is only used if you want to Datalog
Flashhack is needed to Tune / Flash the PCM
So you only need Flashhack
Old Jul 19, 2024 | 04:58 PM
Ayjoki's Avatar
Ayjoki
Ok thank you, I’ll be doing the flash after work and update if any check engine lights remain
Old Jul 19, 2024 | 08:08 PM
Ayjoki's Avatar
Ayjoki
Everythjng works now, speedometer, odometer. No engine check codes! It was just the wrong bin, even the pedal feels heavy and the car more responsive. Thank you all very much for your help
To 1994 C4 problems and codes
