Caliper Ceased - Front Drivers Side
Old Jul 16, 2024 | 06:00 PM
rikkilee vette's Avatar
rikkilee vette
Default Caliper Ceased - Front Drivers Side
1987
Would anyone know what could be causing a ceased front drivers side caliper? We cleaned and resealed/lubed the caliper piston, lubed the sliders. Replaced the left front brake hose. Replaced the master cylinder. We did bleed all the brakes. It took a long time it seemed for the front drivers line to bleed. We then put it back together and the front drivers caliper still drags pretty bad. A solution would be wonderful at this point if someone has an idea, thanks.
Old Jul 21, 2024 | 09:45 AM
Yonker's Avatar
Yonker
Did you replace the rubber flex brake line to the caliper? Those deteriorate on the inside and can collapse not allowing the brake fluid to return, like a one way valve.
Old Jul 21, 2024 | 09:50 AM
Elduderino's Avatar
Elduderino
Okay, i know you replaced all those things but do this. Make it seize up, then loosen the bleeder and if it squirts out its the hose, if not its the piston or slide.
Old Jul 21, 2024 | 11:27 PM
jv9999's Avatar
jv9999
Also, the ABS pump would be a prime suspect in my book.
Old Jul 26, 2024 | 05:58 PM
Kjdad's Avatar
Kjdad
Did you crank on the banjo bolts. If too tight can collapse the passage. Ask me how I know..lol
Old Jul 26, 2024 | 06:40 PM
89onlyZ51's Avatar
89onlyZ51
my money's on the abs pump as well, btdt. Remove the line from the caliper and try to bleed it. If it's still slow, you have your answer.
To Caliper Ceased - Front Drivers Side
