Coolant Temp Switch or Temp Gage Sender?
At the front of the inlet manifold we have our 2-pin Thermo Time switch which controls the activation of the 9th cold start injector for 8 seconds AND the 2-pin ECM Coolant Sensor (yellow & black wires). No problem there. We also have the Low Coolant Sensor that plugs into the RHS of the radiator. No Issue.
BUT ... there are, of course, 2 further locations (between cylinders 1 & 3 and between 6 & 8) for coolant / engine temperature sensors. One is dedicated to feed the water temp gauge, the other is a switch which will activate cooling fan(s) at 227 degrees.
My problem is that I am trying to align the correct item in the correct location. And I don't trust the accuracy of the Shop Manual which seems to be a combination of transitions from 1985 to 1986
Also, the Shop Manual and other sources (eg Haymes) use different terminology throughout their pages for these sensors. The shop manual has a diagram at 8A -201-2 (Component location diagrams) which illustrates a sensor on the left side, but fails to label it. Illustrations on the right side, also fail to positively identify the sensor! So, I figured I would go to the circuit diagrams to look for wire colors .. 8A-82-1 has the IP (Instrument Panel) Coolant Temp Sensor color as blue but does not identify location. Cannot find any wire colors for the switch anywhere. Terminology is all over the place too .. I have seen "Engine Temp Sensor, IP Coolant Temp Sensor, Cooling Fan Switch, Water Temp Conn, etc. ALSO 1986+ models MAY have switched sides of the engine for these 2 sensors from 1985 models.
On my car the RHS (dipstick) has a single green wire, the LHS we have a yellow wire which exits a loom near the alternator, then, in the last few inches, splices into 2 - green and blue wires, into a 2-pin plug.. Go figure! I read somewhere that one of then sensors has a single wire and grounds itself on the engine (we must expose some bare thread to do this).
Engine Wiring section -
6D5-4 illustration labels the 'Cooling Fan Temperature SWITCH " on the RHS.
6D5-3 illustrates the "Water Temp Conn" on the LHS.
Hames manual says the "cooling fan SWITCH" is on the dipstick side, cylinders 6 & 8, 2 pin.
Can anyone provide clarity for a 1986 car PLEASE ... Wire colors would be great too.
The main fan can also be turned on (via the ECM) by the AC pressure switch installed in the AC piping near the dipstick (on my 87 with HD cooling). Some cars with 2 fans are mounted side by side , I am unfamiliar with which condition controls which fan on these.
The temp sensor (grn wire) between cyl 6 & 8 is used to display temperature to the driver on the digital dash.
The HD fan sensor/switch (grn wire with wht stripe on my 87) between cyl 1 & 3 is for HD cooling (on cars with HD cooling such as Z51 Z52 and some other cooling packages) which turns the fan on that is in front of the radiator and / AC condenser. This fan faces the rear of the car and is not controlled by the ECM. It is only controlled by the sensor between cyl 1 & 3.
I test my rear facing HD fan by taking off the connector and grounding it.
Do you have a Z51 Z52 or an RPO code such as B4P ??
Ditch the haines manual and buy a $20 field service manual.
@GraemeR The schematic is from an 86 FSM. Keep in mind some owners liked to wire in switches on a second wire so they could turn this second fan on when they wanted. If so you may find an unknown switch somewhere near the driver. The HD fan relay on mine is mounted on the front top left corner of the radiator cover shroud on the drivers side.
The B4P boost fan is a stand-alone fan controlled only by the temp switch in the cyl head. It is a green/white wire. In 1985 only this switch is on the Passenger Head between #6-#8. In 1986, the switch moves to the Driver head, between #1-#3. Still a green/wht wire.
In B4P configurations, there is no "over-ride" switch in either head for the main fan.
The Gauge Sender is in the Driver Head in 1985 only. In 1986, it moves to the Passenger head. The FSMs I have for the Atari Dash cars show a dk green wire all the way to the sender. (On LT1 cars, there is a short blue jumper wire from the sender down to a connector by the starter motor where it becomes the dk green wire that remains dk green all the way to the cluster. I have no idea if this 'blue wire' or connection exists on a 1986 L98.)
green/white stripe 1/3 for front fan.
I think it was later years that saw twin main fans.
An interesting feature is that if the display is on the other function, Ie the switch has Volts selected, but if there's a Coolant Overtemp, the display switches to Coolant Temp, and if dimmed goes to full brightness and illuminates the Red Square. All done by programming within the cluster.
