Combination for 12's?
Old Feb 3, 2003 | 09:36 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Combination for 12's? (Lord Odin)
What tires are you using? Old hard tires may be what's killing your launch, not to mention giving you other problems you don't even know you have. New sticky tires should improve your launch, handling, braking, and rain traction. Also make it quieter. When I went from a set of old Bridgestones to my new pilots I thought I had put pillows on the rims. :rofl:
Old Feb 3, 2003 | 09:45 AM
Lord Odin's Avatar
Lord Odin
Default Re: Combination for 12's? (92TripleBlack)
I have Bridgestone Potenze RE71's on but I think they were like 2-3 yrs old when I made the run, so that may have been the problem. I still have them on and am due for a new set of wheels. :smash: Hopefully my problem is that simple.
Old Feb 3, 2003 | 10:41 AM
Chronos's Avatar
Chronos
I've got an A4 and found that loading the torque converter just before launching, holding the car at about 1600 rpm, and launching without traction control gives me a hard, fast start. After rolling for a few tire rotations I apply full throttle; I've been able to get just enough tire spin for a solid launch, and then apply full torque without sending the rears up in smoke.
Old Feb 3, 2003 | 02:03 PM
dgoodhue's Avatar
dgoodhue
I would think that 1.9's 60' would be possible, as I have been able to hit 1.9 consistently with real street tires (255 Gatorbacks and 315 Dunlop SP9000), but that will only help you get to 13.6-7's. Have you done a tune up on your car lately, change the fuel filter, even replace you optispark if you have higher miles? What RPM is your tranny shifting at? Something seems a miss that your running only 101mph with a few mods.
Old Feb 3, 2003 | 04:25 PM
Lord Odin's Avatar
Lord Odin
Default Re: Combination for 12's? (dgoodhue)
I had the fuel filter and pump changed last year. Replaced the optispark about 2 yrs ago or so (can you say hydroplane a river?). Never done a tune up (not sure what you mean by that) and I can't remember when my gears shift. I'll find out later today.
Old Feb 3, 2003 | 04:32 PM
dgoodhue's Avatar
dgoodhue
To finish up a Tune up, it would pretty much only be plugs and wires.
Maybe have someone look at it with a scan tool to look at the O2 and to see if it pulling out timing because of knock counts.
Old Feb 3, 2003 | 05:01 PM
Lord Odin's Avatar
Lord Odin
Hmm. Well I just replaced the wires last summer and the plugs 2 yrs ago. Also replaced the O2 sensors 2 yrs ago as well.
I should get a scan though.
Old Feb 3, 2003 | 07:16 PM
Lord Odin's Avatar
Lord Odin
Yup. It shifts to 2nd around 5500 rpm.
Old Feb 3, 2003 | 07:31 PM
Rob K's Avatar
Rob K
A head and cam package would probably do it. A higher stall converter with some
3.42's or 3.73's with some drag radials would probably get you close, but probably not all the way. I'm not sure what converter works well with an A4 C4, but possibly something like a Vigilante 2800.
:cheers:
Old Feb 3, 2003 | 07:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Combination for 12's? (Rob K)
:cheers:
That's what I have.
Just to add some more, I was getting 1.9 60's with street tires and the stock torque converter, ASR off and no problem with traction at all.
