Combination for 12's?
Old Feb 2, 2003 | 03:57 PM
Lord Odin's Avatar
Lord Odin
Default Combination for 12's?
Before I get anything else for my car, I was wondering what are some setups people are using to get into the 12's on daily driver cars w/o N20. I was thinking about the SC route but I thought I'd ask what other people are using first.
Old Feb 2, 2003 | 04:15 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Combination for 12's? (Lord Odin)
I did gears and a high stall Torque converter, so far it's only got me to 12.99, but the car needs new plugs and wires and stuff like that, and I still have the stock exhaust.
Old Feb 2, 2003 | 04:17 PM
Black96Corvette's Avatar
Black96Corvette
Default Re: Combination for 12's? (Mr Mojo)
With a D44 and 3.73's and a Vigilante Torque Converter, you'll be in the 12's EASY. Panuzzo has this combo and you'll hit lower than a 12.9 w/ good traction. I'm debating what route i'm going to be taking and I think I am gonna copy Panuzzo's exact combination. GL on your search.
Old Feb 2, 2003 | 04:38 PM
gears's Avatar
gears
My stuff is in my sig.Its just one option of many.
Old Feb 2, 2003 | 04:45 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Mid 12 are easy to reach without going into the motor.
Old Feb 2, 2003 | 04:47 PM
Lord Odin's Avatar
Lord Odin
Default Re: Combination for 12's? (mackeyred96)
I agree but I have a convertible with an auto tranny. That's about 1 full sec slower than a 6 spd coupe and will make it even tougher for me to get into the 12's. I'm around 14 flat right now, so I have another 2 secs to gain and I figure the only way to do that is through the engine. If don't need to, that'd be great though!
Old Feb 2, 2003 | 05:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That 101+mph trap speed is indicative of around 275CHP for a 3370lb Vette; with your mods you should be building around 320CHP which would be good for a best of 12.7sec at 106+MPH.
Was the track hot that day or at a high elevation??
Old Feb 2, 2003 | 06:25 PM
Bruce's Avatar
Bruce
Default Re: Combination for 12's? (65Z01)
Heads/cam will put you in the 12s. I did it in my 93 convertible. When you are in the 12s and you will want more, that is why now I got blown 383ci and the juice.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
Old Feb 2, 2003 | 06:44 PM
Lord Odin's Avatar
Lord Odin
I raced at Rt 66 on at around 76 degrees (i think). I've raced it about 10 times in varying conditions but none of them got me below the 14 sec mark.
Old Feb 2, 2003 | 06:53 PM
vader86's Avatar
vader86
What are your current 60' times?
All you should need is some gears and the right TC, you should get very close with those 2. 1.6rr would be a good mod too.
Old Feb 2, 2003 | 08:29 PM
Lord Odin's Avatar
Lord Odin
Default Re: Combination for 12's? (vader86)
Here's my times for my best run:
60' - 2.134
330 - 5.997
1/8 - 9.151 @ 78.91
1000 - 11.817
1/4 - 14.078 @ 101.29
This was before I got chrome rims put on, so I'd expect my times to be even slower now.
Old Feb 2, 2003 | 08:40 PM
vader86's Avatar
vader86
60' - 2.134
Thats pretty rough, you need to keep going to the track and get that down, then youll be in the mid/upper 13s. Dont put your money on mods until you can drive the car in stock form, otherwise youll still be spinning the tires at the line.
Old Feb 2, 2003 | 09:00 PM
Darkness's Avatar
Darkness
Long tube headers, and new exhaust along with some goodies like 52mm TB, gears, should get you there. Anyways keep asking :cheers:
Old Feb 2, 2003 | 10:41 PM
Lord Odin's Avatar
Lord Odin
I can't get it to go any faster at the line without breaking traction. I believe on that run, I got a good line and when it shifted (chirped both times). If I try revving it anymore at the line, I'll break traction and just spin.
Old Feb 2, 2003 | 11:01 PM
Mr Mojo's Avatar
Mr Mojo
Buy or borrow some drag radials and you'll see 1.9 60's at the very least and that will get you in the high 13's no problem.
Old Feb 3, 2003 | 12:56 AM
Lord Odin's Avatar
Lord Odin
That's just it. I don't want to use them because I'm afraid for my tranny. That and I want to know what my car can do as a daily driver.
Old Feb 3, 2003 | 01:57 AM
Ken Lanham's Avatar
Ken Lanham
My vote goes towards gears for one of your next mods. That should be worth a few tenths alone. Not 12s by itself. But most modifications you make will get along better with a higher ratio gearset. 3.73s if you can tolerate the extra rpm.
:yawn: off to bed
To Combination for 12's?
Old Feb 3, 2003 | 02:07 AM
Lord Odin's Avatar
Lord Odin
Default Re: Combination for 12's? (Ken Lanham)
I was thinking about doing gears at one point. I was thinking about doing the 3.73's at first but I heard they gave problems more freuently because of pinions and that I would be better off with 3.54's. I was later told that if I was gonna do that, I should just go with a Dana 44 because they come with 3.54's in them and the extra strength would be useful.
[Modified by Lord Odin, 12:08 AM 2/3/2003]
Old Feb 3, 2003 | 05:35 AM
93 ragtop's Avatar
93 ragtop
I got mine down to 12.91 on the Mich. Pilot tires with the mods in my signiture. Also that was with the hardtop on. Try staying out of the water, do a short spin before staging, just enough to clean the dirt off of your tires. Also try both ASR on and off. I agree with others that you need a better 60 ft time. My best has been 1.78. Also, I was told that for every 1/10 you drop in the first 60ft will equal approx. 2/10 at the end.
Old Feb 3, 2003 | 08:05 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Combination for 12's? (93 ragtop)
That's some good numbers you got there.
