Porting plenum and ???
Old Feb 2, 2003 | 08:56 PM
blk90rdstr's Avatar
blk90rdstr
Default Porting plenum and ???
I was pulling off my T.B. to clean and do the coolant by-pass mod. and i decided to remove the plenum. I gasket matched all the holes and cut out the WALLS behind the T.B. ports. I polished the plenum and runners too. what do you guys recommend i do while its apart like this. Simple stuff nothin real radical. :leaving:
Old Feb 2, 2003 | 09:05 PM
StealDads67's Avatar
StealDads67
Default Re: Porting plenum and ??? (blk90rdstr)
Sounds liek you got most of it.... unless you want to take the intake manifold and port that.... Supposedly that is where you will gain the most power.... I dont know from experiance though..... Oh and go for a AFPR while your under there..... Helps for tuning your car and it comes with the new gaskets to put the plenum back on
BTW= How do you like your LT1 exhaust? I just picked one up for free.... Im going to get rid of the front Y and put 2.75" pipes straight back to the resonator..... What do you think?
[Modified by StealDads67, 2:06 AM 2/3/2003]
Old Feb 2, 2003 | 09:35 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Porting plenum and ??? (StealDads67)
Thanks. I like the LT1 exhaust alot. It looks great, its not real loud but very distinct. I have the 2.75 pipe from mufflers to cat. My precats are removed and my main cat is sleeved. I really cant say about the performance since i rarely drive her let alone get into it.
The AFPR sounds like a plan. I hear it dont do much without computer mods but a chip is coming. It will assure i keep that 35 lbs of press.
Is there a guage for feul pressure that i can keep underhood ?
Old Feb 2, 2003 | 11:21 PM
chucks88's Avatar
chucks88
How about sending your injectors out to be cleaned/flow tested. You can also change your EGR valve (mushroom lookin' thing under plenum)
Old Feb 2, 2003 | 11:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might want to also:
install a 160 deg stat and fan sw,
do the TB coolant bypass,
relocate the MAT into the air filter lid
and cut back the spark plug ground electrodes (see my site).
To Porting plenum and ???
