Verdict on Vortec TPI?
Old Feb 3, 2003 | 12:32 AM
sunrise.cm's Avatar
sunrise.cm
Default Verdict on Vortec TPI?
Any feedback on Vortec TPI is appreciated:
http://www.sdpc2000.com/htm/vortec_tpi.html
Old Feb 3, 2003 | 11:48 AM
hz900's Avatar
hz900
Default Re: Verdict on Vortec TPI? (sunrise.cm)
Pretty good numbers I think, wonder if they are accurate. With a little P&P I'm sure you could get more out of it.
Old Feb 3, 2003 | 11:56 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
The only difference between the Vortec TPI baseplate and the OEM baseplate is the Vortec plate has the bolt holes properly located and angled for the Vortec heads. So basically what you're looking at there is what kind of power can be had from adding the Vortec heads to the motor, as that is what is effectively changing.
The stock L98 heads suck, but there is a lot of good work that can be done to them by a good port job (with access to a flowbench) When I ported my heads a few weeks ago, I dropped 0.7 second and gained 8 mph in the 1/4 (on a track that doesn't hook as well) The only other mod I had done to the car since it's previous best was a ZF swap, and the ZF has taller gears than the 4+3 which would have hurt the car's acceleration. I will be doing a gear swap this weekend to bring the net gear ratios back to stock, as well as putting in a stronger clutch. Then we'll see what the head porting really did to the car's power.
Old Feb 3, 2003 | 12:15 PM
Chief Muktar's Avatar
Chief Muktar
Default Re: Verdict on Vortec TPI? (CorvetteZ51Racer)
hey z51racer, by those numbers it looked like oyu gained ~75 hp by porting those heads (.1 sec or 1 MPH is worth about 10hp) I didn't think that these dport heads could get that good. :confused:
Old Feb 3, 2003 | 12:18 PM
CorvetteZ51Racer
Default Re: Verdict on Vortec TPI? (Chief Muktar)
the estimates are that I did gain about 60-75 hp and about 60-75 lb-ft at the wheels from the port job. When I get the new clutch and gears (and rear tires :D ) installed, I plan on getting the car dynoed and will let you know what the gain was. Previous numbers were 228 rwhp and 336 rwtq on MSR's old dyno.
Old Feb 3, 2003 | 03:27 PM
Jsailor24's Avatar
Jsailor24
WOW! how muh is a port/polish job? I could take my heads off. How much to have the machining done? .7 WOW. :eek: :auto:
To Verdict on Vortec TPI?
