Headlight Switch; interior lights not working.
Old Aug 3, 2024 | 09:53 PM
Vindkast's Avatar
Vindkast
Cruising
Default Headlight Switch; interior lights not working.
Hello! I'm trying to fix a couple of problems with my interior lights, I looked around in the forums so I have an idea of where to go but still can't figure something out.
No lights turn on with doors open but security does flash so I'm assuming this is the delay timer not working. Door hatch buttons don't work either. I don't mind, the switch for the headlight dims the console lights but it doesn't turn on the interior lights
Ps; the lights do turn on by clicking them. 1985 C4.
Thanks for any help in advance.
Old Aug 3, 2024 | 10:53 PM
s carter's Avatar
s carter
A lot of what you mentioned has to do with the coursey fuse, is there any problem with the radio
Old Aug 4, 2024 | 01:58 AM
Vindkast's Avatar
Vindkast
Cruising
The CTSY fuse you mean? It works just fine, aftermarket radio but it works correctly to my knowledge. . .
To Headlight Switch; interior lights not working.
