86 cold start/stall issues
Old Aug 5, 2024 | 06:29 PM
gcb1955's Avatar
gcb1955
4th Gear
Default 86 cold start/stall issues
Newbie here on Forum. Just bought first Vette(86), early with cast iron heads/TPI. Will turn over and instantly start but will stop after 10 seconds. Have to start/stalls until 160-170 degrees. Might stall one more time at a stop light if I open the throttle too quickly. After reaching op temp it will run forever. I read about the CSV(injector) but could not find it. Is it under the plug wires running from the distributor? Very tight back there. Also heard of a fuse behind radio/screen in the middle of dash. Am I pointing my self in the correct direction? Thanks in advance for any help or link to a troubleshooting sequence.
