removing FX3 actuators
Old Aug 10, 2024 | 12:48 PM
TomD76's Avatar
TomD76
Cruising
Default removing FX3 actuators
not the actual removing them from the shocks, thats easy and i got that. but if i need to remove the actuator entirely from the car and send it out, the right front one appears to be a bit complicated as the wire passes under a few things related to the engine that the connector won't squeeze by. is there some simple way to get it out without taking a bunch of other stuff out of the way that i'm not seeing? the left one comes out easily and isnt pinched behind anything.
related, when/if i attempt to take the back ones out, am i going to encounter any similar sort of situation where the wires are pinched behind something that needs to be moved out of the way to get them out?
