climate control
Old Aug 11, 2024 | 09:31 PM
joeypastaman's Avatar
joeypastaman
Cruising
Default climate control
so i have a brand new climate control but ac blows very low on 10 and blows from ac vents, defrost vent and heat vents...blower motor bad or something else?
Old Aug 11, 2024 | 10:11 PM
s carter's Avatar
s carter
Did you hear the fan speed change, also the problem with the vents can have several layers of problem, it could be as simple and cheap as a vacuum source at engine off or broken or be a corrosion/Blown Capacitor in the AC Module mounted on firewall Left side against the "A" Pillar
Old Aug 12, 2024 | 12:14 PM
joeypastaman
Cruising
I do hear the fan speed change...I mean i said its low on 10 but in all actuality it blows alot harder thru the heat and defrost vents than it does thru the ac vents, but I will check the capacitor.. Appreciate the help
Old Aug 12, 2024 | 12:21 PM
drive it's Avatar
drive it
I got a kit from batee.com and repaired that controller myself. It's up under the dash on the driver's side. If you can solder you can fix it with the kit from batee. And check the incoming and outgoing vacuum lines first.
To climate control
