Odometer Broken Need Help Please
Old Aug 27, 2024 | 03:05 PM
Trentin_Halp's Avatar
Trentin_Halp
Default Odometer Broken Need Help Please
Am trying to fix my 84 C4 odometer cause it doesn’t work and when I took it apart I see the piece in the back holding all the pieces together is broken. Anyone know what the part is or where I can find ones thanks!
Old Aug 27, 2024 | 03:15 PM
s carter's Avatar
s carter
Does that piece just lift off or is it anchored into the mechanism, because I wonder if you could go to junkyard and salvage it from a other vehicle relatively same age bracket with a Analog Odometer
Old Aug 27, 2024 | 03:16 PM
WVZR-1's Avatar
WVZR-1
If there's still a speedometer repair shop in your area it would be for sure likely available there. That's a 7 roll indexing retainer.
Old Aug 27, 2024 | 03:18 PM
Trentin_Halp
It lifts off
Trentin_Halp
Originally Posted by WVZR-1
If there's still a speedometer repair shop in your area it would be for sure likely available there. That's a 6 roll indexing retainer.
There isn’t. I see eBay is selling odometers that work. Would I be able to just swap it out?
Old Aug 27, 2024 | 03:27 PM
WVZR-1's Avatar
WVZR-1
Message this guy on eBay and supply him your snapshot. He mentions having many odometer, speedometer parts for earlier GM
https://www.ebay.com/itm/40488972622...Bk9SR97C-tOyZA
*** Fabricate your own ?
Old Aug 27, 2024 | 03:36 PM
Trentin_Halp
Awesome! Thank you!
Old Aug 29, 2024 | 06:32 AM
64Scout's Avatar
64Scout
Ages ago I had the same issue, so I used an exacto and cut one out of a 2 liter pop bottle.
On my 89, it doesn't have that piece, those tabs fit in a slot in the housing.
Old Aug 29, 2024 | 08:46 AM
Kilobuck84's Avatar
Kilobuck84
Those were designed to reveal odometer tampering, so they're intentionally flimsy. Cutting a piece out of something as 64Scout said would work well enough.
To Odometer Broken Need Help Please
