Lowering With Wedges
If you are talking about the bracket that goes under the bushing and attaches to the frame, you'll need to trim it about the same amount that you removed from the rubber above the frame. Oh...wait a minute. You might be talking about the aluminum shims that go between the bracket, bushing, and the frame. These should be removed as well to give you a little more lowering. I had to re-use them on the undreside of the bracket as spacers because I didn't want to replace the bolts through the frame with shorter ones. I hope all of this makes sense. :)
If you haven't cut the bushes off yet, measure how tall they are with the metal shim on top. Then measure the height of the lowering wedge. The difference between the two is how much height you have to trim from the facing edges of the aluminium spring retainers. Becasue you have to trim the retainers (so they still hold the spring securely) you will likely not have enough thread to do the nuts up all the way when reinstalling them - this is when you install the metal shim between the spring retainer and the bolts (you may need to use some washers or something as well if you still don't have enough thread).
By the way, not all cars have the metal shims.
HTH
[Modified by Red 90 L98 Coupe, 1:33 PM 2/5/2003]
What about the bushings on the very end of the spring, If you cut these I would think that it would move the a-arm up raiseing the wheel in the fender thus getting the car a bit lower.....Right?
Another option is to not use the wedge at all on top of the spring. I would recommend using some sort of thin rubber insulator to protect the spring where it will rub on the chassis (ie: where the wedges fit) though.
Also, remember to lube the contact points for the spring when you re-install (ie: where the spring pads in the crossmember and under the outside wdge of the spring. Use a non-petroleum base grease.
HTH
I just used the stock kit and while I wouldn't mind going a little lower, I have to be cautious enough about bumps as it is. Also, the rear end will be sitting pretty close to it's bumpstops if you lower it to the standard kit height (it is on my car anyway).
FWIW, some people here have reported the top of the front tyres hitting the inside of the fender guards on big bumps when combined with a soft supension and extreme lowering - not trying to scare you but you have to be aware.
The end bushings are cut, and wedges are going on tonight, I'll post pics when its done :cheers:
Look forward to your pics, I think it will be in the weeds when you are done. :cool:
[Modified by Red 90 L98 Coupe, 7:39 PM 2/6/2003]
