L98 Procharger P600B false knock?
What do you think about this, is this possibly a false knock?
I've had some problems this summer when I replaced a larger throttle body and I've had to adjust the VE and AFR table again.
I know the P600B supercharger is loud as is the ZF.
Methanol/water injection should prevent the occurrence of knocks...and as you can see from the log, the cooling drops quickly.
Previously, when driving at full throttle, the AFR was around 11.80 at the beginning (MAP over 100) and 10.80 at the end (MAP 160)
Now the AFR has been around 12.70 at the beginning and 11.60 at the end and I have enriched the engine but maybe I need to enrich even more.
The car was tuned on the dyno last summer and there was no knock then.
Sometimes it appeared as a spike when I changed gears in normal driving.
What kind of AFR do you run the engine best without knocking?
Now there have started to be knock spikes like this in the logs.
Here's acceleration in 2 gears
Here's acceleration in 3rd and 4th gear
Here is the AFR and VE table
Another factor is that under load, ethanol content in gasoline produces higher flame speeds which is effectively more ignition timing, so MTB is at a lower timing value for the same peak pressure... except of course it's more than offset by knock resistance where timing is knock limited... but we're talking MBT timing here and the factor mentioned above.
Sorry for my misunderstanding, I meant that the idle didn't work for me when I changed the throttle body to a BBK 58mm one.
Methanol / water mix is 50/50% and it should be fine, but I will fill up again in the near future.
I also have the original KS
I have to tune the VE and AFR table even more so that I get AFR under 12.00 as soon as I press the gas pedal.
Also I need to add more Accel enrichment because the AFR runs really lean as soon as I hit the gas.
I see knock counts in the lower gears especially during wheel spin, but typically not in high gear/high load when the car is hooked up where it should be more likely to knock.
I am also of the opinion that the knocks coming from a low gear are probably false.
But I adjust the AE and VE table and yes it will be good then
