What's making this noise?
Old Sep 25, 2024 | 12:06 PM
Joe K's Avatar
Joe K
2022 C4 of the Year Finalist - Unmodified
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (appearance mods) 2019
Default What's making this noise?
Hello. My 85 is making an engine compartment noise. I've stethoscoped it but not certain. I think it's the AIR Pump. Tell me what you think.
Thanks for looking.
Joe K
Old Sep 25, 2024 | 12:17 PM
Elduderino's Avatar
Elduderino
Sounds like it may be a pully bearing trying to come out
Old Sep 25, 2024 | 12:56 PM
s carter's Avatar
s carter
First Pop the drive belt off the pulleys you can leave it hanging just give a little push down from crank, next give a good look at the crank balancer see if there is rubber hanging out or it's rubbing the timing cover.
If the above is all good, with the belts off engine off turn each drive (Pulleys) feel for looseness or grinding, if you feel all is well belt off run car for SHORT TIME LESS THAN 2 MINUTES and listen all you should hear is motor if you still hear the noise it's in the motor and that's another can of worms
Give the Idler pulley a good look it's a common fail
Old Sep 25, 2024 | 01:32 PM
Joe K's Avatar
Joe K
Thanks to you both for the tips. I have checked all the items you've mentioned. I haven't ran it with the belt removed. When I get a chance I will do that and also recheck the pulleys. Thanks again.
Joe K
Old Sep 26, 2024 | 01:37 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Hey Joe, sounds like inside vanes of air pump.
if you have a long stick or long screwdriver (or a mechanics stethoscope) hold it on the body of the air pump, the ac compressor, and the alternator…and other end put it right onto your ear like u r trying the feel vibrations up the ear. it will work.
BUT! be careful about dropping it or wearing ling clothes or hoodie strings getting caught up.
Old Sep 26, 2024 | 06:17 AM
Joe K's Avatar
Joe K
Thanks. I bought a stethoscope and the sound does seem to be coming from the air pump. Gets louder as the longer the car runs.
Old Sep 26, 2024 | 07:25 AM
VikingTrad3r
Oil Producer
ok, if you hold the steth on the pumps body does it get louder towards the front where the bearing is?
i had an 86 early iron head car with the same air pump, i was driving to the track and the bearing got so hot that it softened the pot metal of the pump body and the belt pulled the pulley wheel right off!
Needed a side of the highway rescue.
i had to install the air pump delete kit until i sourced a replacement air pump, which was from a local cf member.
Old Sep 26, 2024 | 07:56 AM
Elduderino's Avatar
Elduderino
Well done mate! Pop off the belt and confirm. Perhaps your in a State where you could just "delete" the AIR pump?? Either way i think you have it figured out.
Old Sep 26, 2024 | 08:46 AM
Joe K's Avatar
Joe K
VikingTrad3r, definitely coming from the front.
Elduderino, no emissions testing in Kentucky so I'm good.
Going to check it out a little more but I'm sure I'll be getting a delete pulley.
Joe K
Old Sep 26, 2024 | 09:58 AM
2011KLR's Avatar
2011KLR
Check out this video. Unless you are set on doing the delete, this could save you the money.
Old Sep 26, 2024 | 12:26 PM
Joe K's Avatar
Joe K
Thanks 2011klr will do.
Old Oct 15, 2024 | 04:01 PM
Joe K's Avatar
Joe K
I installed this pulley kit I purchased from Walmart. Nice kit, fair price, looks good.. Air Pump Kit Noise and vibration gone, at least during the short test drive I took after installing. Easy to install, only thing was it didn't come with instructions but this youtube video was a great help.
Here's a couple of pics.
Thanks for the help and for looking!
Joe K
Old Oct 16, 2024 | 10:11 PM
2011KLR's Avatar
2011KLR
Cool find. For tthat price I might add this to my ever growing todo list
Old Oct 21, 2024 | 11:23 AM
Joe K's Avatar
Joe K
Well unfortunately that didn't take care of the problem. Going to be checking the harmonic balancer.
Joe K
To What's making this noise?
