Headlight not closing
Old Feb 4, 2003 | 10:59 PM
aroulette's Avatar
aroulette
Default Headlight not closing
While having my hood up, I turned th light on and it rotated half way and stopped. Now I cant get it to rotate all open or closed. Any ideas?
Old Feb 4, 2003 | 11:17 PM
Black85L98's Avatar
Black85L98
Default Re: Headlight not closing (aroulette)
Does it try? You may have someone push on it when you turn them off. If the motor is not running check the connections and relays. If the motor is running you have
#1 Bad gears in the early style
#2 Bad bushings in the newer style
I hve replaced the gears, not a bad job.
