1989 L98 MAT sensor Function
Old Sep 27, 2024 | 08:10 AM
Woodbadge2017's Avatar
Woodbadge2017
3rd Gear
Default 1989 L98 MAT sensor Function
Receiving Code 23. After reading several threads, it appears in the early years( before '89) the MAT only controlled the EGR valve. Also I read, there were a lot of changes to the '89 models, one of which used the MAT to help control fuel mixtures. The production date on my '89 is 10/88. Question is, would it follow the '88 models or '89 models? Thinking about relocating the MAT sensor to the air filter housing. Thoughts Please.
Old Sep 27, 2024 | 08:49 AM
mlm0's Avatar
mlm0
I did that to my 89. Bought a relocation kit and drilled hole in my air filter plastic just ahead of throttle body. I didn’t notice any difference. I wouldn’t do it again
Old Sep 27, 2024 | 08:54 AM
Woodbadge2017
3rd Gear
Thanks. I know my MAT sensor is bad. Would you pull the plenum and change it ?
Old Sep 27, 2024 | 09:56 AM
ULTM8Z's Avatar
ULTM8Z
Looking at the 6E code in Tunerpro, it seems that only the EGR is controlled by the MAT sensor. So relocating it won't really buy you anything.
Which kinda makes sense... if you have a MAF sensor that actually (as it's name indicates) measures the mass of the air coming in, that measurement already takes into account the air temperature since temperature affects air density, which affects the mass of the air coming in.
On a MAP car (90-91), where the airflow is only calculated by the ECM (and not measured), it needs the air temperature to make that calculation such that it can adjust for changes in air density over temperature. So the MAT sensor relocation can make a difference, but only if you recalibrate the tune for it. The tune takes into account the heat soaking that occurs by having a metal sensor in the plenum. If it gets relocated you need to tell the ECM that.
Old Sep 27, 2024 | 03:09 PM
tequilaboy's Avatar
tequilaboy
Are you sure its plugged in? Look for the short jumper harness behind the distributor that leads to the MAT under the plenum. Check the wiring integrity and/or resistance if you can get to the two pin weather pack connector on the jumper.
In 89 cars the MAT may also have minor influence on the startup enrichment at high temperature and the idle speed time out keep alive IAC steps. Only applies to a hot-restart situation and only a minor influence at that. These features can be optionally configured to use either the MAT or the Coolant temperature as inputs.
I don't know if I have any $6E data showing the IAC behavior at IGN off and during the keep alive period but I will see what I have.
There is no point in relocating the sensor unless you know what you're doing and can modify the code to make better use of the MAT/IAT for some other purposes.
To 1989 L98 MAT sensor Function
