antenna mast
Old Feb 5, 2003 | 12:51 AM
1990white's Avatar
1990white
Default antenna mast
My mast has failed me!!!! Just one of many things that has failed. But, thats part of owning a car, I think!!! How do I remove the gromet to reach the nut to remove the mast? 1990 coupe. Thanks
Old Feb 5, 2003 | 01:50 AM
vettl83's Avatar
vettl83
Default Re: antenna mast (1990white)
If you purchase the antenna mast kit from GM it will have the little tool to remove the mast and the destructions to install the new one. The last mast kit I bought was 29.00 84 CF 91 ZR-1
Old Feb 5, 2003 | 09:11 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: antenna mast (vettl83)
:iagree:
Old Feb 5, 2003 | 09:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It wasn't that simple for my 86 coupe. I had to remove the rear wheel,remove the inner fender,unbolt antenna bracket and then squeeze my arm between all the other stuff to get to the big plastic nut on the antenna tube. Then i had to pry off the large rubber gromet where the wires enter the body. After all that i could finnaly remove the antenna and repair it. All my g.m. antenna kit was the nylon rod attached to the finial end of the antenna. Good Luck :cheers:
Old Feb 6, 2003 | 11:25 PM
1990white's Avatar
1990white
Default Re: antenna mast (dankai)
Thanks for your help. It made the job so much easier to do. I'm glad I found this site. Martin in Carlsbad, CA. :hurray:
Old Feb 6, 2003 | 11:26 PM
1990white's Avatar
1990white
Default Re: antenna mast (PTz-92-LT1)
I'm glad you agreed!!! It all worked out great. I now have happy tunes. Martin in Carlsbad, CA :hurray:
To antenna mast
