Clunk in back end --Need serious analysis (not random guesses)
Old Sep 28, 2024 | 04:13 PM
rremesal's Avatar
rremesal
Default Clunk in back end --Need serious analysis (not random guesses)
Team,
I have been battling thing clunk/thud for about 10 months now, and I still can't figure it out.
- It's a clunk and/or thud...as if something is shifting or moving. I can actually feel it hitting.
- It only happens when I "enthusiastically" take off from a stop. Hold RPMs up to 1.5K or so, slip the clutch out some and then fully release. I'm not dumping the clutch at all
- It DOES NOT do the sound when backing up, going on an inclined driveway, going over a speed bump, hitting a pothole or expansion join. It only makes the sound when taking off.
I have replaced:
  1. All u-joints (main shaft/half shafts)
  2. both sway arms end link bushings (main bushings look ok)
  3. All wheel hubs (front and back)
  4. Dog bones bushings
I have tightened:
  1. C- beam (went 5-10 lbs. over spec front and back)
  2. Rear leaf spring holding bolts (the ones on the diff...they were tight regardless)
  3. All bolts/nuts associated with removing both rear knuckles (torqued to spec after installing new hubs)
I have checked:
  1. Fuel tank is not moving
  2. EVAP canister is not moving
  3. Visual inspection did not reveal anything
In my opinion, the mechanics of suspension flex and or movement is causing this. I feel like something in the suspension either has a worn bushing (batwing maybe?) or is lose (camber rod brackets bolts/nuts)
What am I missing? What haven't I checked?
Thank you,
Ric
Old Sep 28, 2024 | 05:54 PM
FostersPerformance's Avatar
FostersPerformance
How about checking the motor mounts?
Old Sep 28, 2024 | 07:02 PM
rremesal's Avatar
rremesal
It is definitely coming from the rear. May have something to do with rear squat... Don't know!
Engine mounts are new.
Old Sep 28, 2024 | 08:49 PM
drive it's Avatar
drive it
sounds like you've ruled out everything except worn/damaged ring and pinion.
Old Sep 28, 2024 | 09:56 PM
rremesal's Avatar
rremesal
Wouldn't that make constant noise or clunking?
Old Sep 30, 2024 | 12:54 PM
mlm0's Avatar
mlm0
Even though you have tightened down the torque tube, there is a certain distance it has to be from the ( can’t remember if it was frame or floorboard? Anyway, it could be twisting just enough to make contact, thus the noise. Check repair manual for that measurement
Old Sep 30, 2024 | 04:08 PM
383vett's Avatar
383vett
Exhaust system?
Old Sep 30, 2024 | 04:28 PM
rremesal's Avatar
rremesal
This is possible, and in my mind a prime suspect.
Thanks for the tip.
Edit: BTW, I'm sure you meant the C-Beam or torque arm.
Old Sep 30, 2024 | 04:32 PM
rremesal's Avatar
rremesal
Originally Posted by 383vett
Exhaust system?
I got under the car last Friday, and one of the things I checked was exhaust system movement. Other than slight movement back-and-forth at the rear hangers (under the rear bumper), there is no issue I can see. The slight movement is perfectly normal as the hanger is built to "slide" on its rubber holder.
Thank you.
Old Sep 30, 2024 | 04:47 PM
NickPSI's Avatar
NickPSI
Spare tire? (This is a random guess)
Old Sep 30, 2024 | 04:52 PM
rremesal's Avatar
rremesal
Removed along with all brackets
Old Sep 30, 2024 | 05:13 PM
tequilaboy's Avatar
tequilaboy
Try rolling the car backwards in neutral slowly and stabbing the brakes hard. Maybe take a video to see the wheel movement relative to the body. This should isolate the knuckle and dogbones from the drivetrain.
Old Sep 30, 2024 | 05:19 PM
rremesal's Avatar
rremesal
Good idea...will do.
Old Sep 30, 2024 | 05:21 PM
Elduderino's Avatar
Elduderino
What year is the car? Are you in NE Florida by chance?
Old Sep 30, 2024 | 06:32 PM
eyedrron's Avatar
eyedrron
If does it when turning? Clutches in positraction.
Old Oct 1, 2024 | 02:29 AM
mlm0's Avatar
mlm0
Thanks for the tip.
yes, you are right, thanks. Be sure to keep us up to date on what you find
Old Oct 1, 2024 | 06:39 AM
s carter's Avatar
s carter
Probably already hit but the things that I have found to make that kind of noise is the C beam (Hit Hit again so out of loop) and the sway bar and ends being not seated in bar. They may be tight but tight enough. Also same with Shock Absorbers.
One Last afterthought, You Don't have a Forgotten Beer can or Lock Lug Key rolling around the Behind seat storage
To Clunk in back end --Need serious analysis (not random guesses)
Old Oct 1, 2024 | 09:09 AM
Phobos84's Avatar
Phobos84
By your description I had the same noise. It drove me nuts. It seemed it's loudest if I was beating on it and the trans shifted from first to second. I finally found out that the top of the C beam was hitting the fiberglass tunnel under the car. It hit so hard that it broke a small hole through. BUT before you think this is your problem understand that my car is 4L80e swapped with a fabbed C beam adapter. So my geometry is different than yours. But it might be worth a look just to see if there are any impact marks above the C beam near the transmission tail housing.
Old Oct 1, 2024 | 09:48 AM
rremesal's Avatar
rremesal
96 LT4/MN6. NW Florida...Panama City.
I know that grinding sound the diff clutches make. That's not it. It's definitely a thud that I can feel.
​​​​​​​By your description I had the same noise. It drove me nuts. It seemed it's loudest if I was beating on it and the trans shifted from first to second. I finally found out that the top of the C beam was hitting the fiberglass tunnel under the car. It hit so hard that it broke a small hole through. BUT before you think this is your problem understand that my car is 4L80e swapped with a fabbed C beam adapter. So my geometry is different than yours. But it might be worth a look just to see if there are any impact marks above the C beam near the transmission tail housing.
​​​​​​​Probably already hit but the things that I have found to make that kind of noise is the C beam (Hit Hit again so out of loop) and the sway bar and ends being not seated in bar. They may be tight but tight enough. Also same with Shock Absorbers.
I agree with your comments about the C-Beam. The fact the thud happens when I shock (even mildly) the drivetrain, leads me to believe something is making contact under load. My main suspect is the C-Beam; however, I will also check the batwing, shocks, and other suspension components again in case I missed something.
Thank you all for the suggestions...I really appreciate it.
​​​​​​​Ric
EDIT: BTW, s carter...I like my beer from bottles. Keeps the product cooler, longer in my opinion. Also, I "try" not to drink when I'm under the car. Sometimes I succeed...sometimes I fail. ​​​​​​​
Old Oct 1, 2024 | 10:41 AM
s carter's Avatar
s carter
The Can was a Chuckle point for snicker a Little Vevity helps when facing a PITA noise
