Power driver seat
Old Oct 11, 2024 | 01:33 PM
407Tomahawk's Avatar
407Tomahawk
4th Gear
Default Power driver seat
Seat doesn't move forward or backward
Old Oct 11, 2024 | 01:51 PM
Soundwave's Avatar
Soundwave
Umm...ok.
This is insufficient data for anyone to start giving you advice. Could range from a detached connector to a burned up motor. Put in a bit of effort and describe the issue and what diagnostics you have performed so far. Has it ever worked? Can you hear the grind of a motor? What can you tell us. Tell us the year of the car.
Old Oct 11, 2024 | 04:43 PM
jv9999's Avatar
jv9999
Try moving the switch back and forth many times, like 50. A lot of times this cleans the contacts enough to get it working.
Old Oct 11, 2024 | 05:41 PM
407Tomahawk
4th Gear
Default Sorry
Originally Posted by soundwave
umm...ok.
sorry turd head!
I haven't even bought the car yet!
That is info i got from seller.
Thought someone else in a forum setting might have had a simular issue.
Old Oct 12, 2024 | 11:29 PM
7T1vette's Avatar
7T1vette
Nasty! How would anyone know you hadn't bought the car from what you wrote in the first post? You're new here. Clean up your act if you want to get along....
Old Oct 31, 2024 | 04:37 PM
shawn 84&92's Avatar
shawn 84&92
He is new here, but the reply he got of "Umm...ok" was rude and would have ticked me off too.
There is a way to ask people for more info without trying to make them look stupid.
Old Nov 1, 2024 | 04:04 PM
dburgjohn's Avatar
dburgjohn
to the original question
check fuse, if good move on
check for power at the connector under the seat, if you have FSM and know what color wires make it move you could jumper power and see if seat moves. if seat moves when jumped but not power at seat connector check for power at the switch
Those are the most likely, if nothing shows up there and there is no power to switch, you have to trace the wire and find break or redneck it and bypass with a new fused wire to switch
Option D, find a trusted mechanic
good luck
To Power driver seat
