rebuild l98
Old Nov 1, 2024 | 08:43 AM
santazr1's Avatar
santazr1
Default rebuild l98
rebuildinga l98 and want to addd some power to car but keeeping orginal throttle body. What can be done to motor to help it out breathing with more hp
thanks
Old Nov 1, 2024 | 03:12 PM
Incorvettei's Avatar
Incorvettei
Port and polish the upper and lower intakes, add a set of heads similar to AFR 195’s, a bigger cam shaft and a set of long tube headers. This will eliminate the front 2 catalytic converters and run dual pipes through an x pipe to your choice of mufflers. If you want to deeper than the top end rebuild have the cylinders bored .030 over and you will have a 355 that will be pretty potent. If you still want to go further swap out the crank shaft and make a 383 stroker out of it. All this cost money and it is up to you and your pockets how fast and powerful you want it to be.
