94 AC/ps bracket
Old Nov 3, 2024 | 05:54 PM
Gasnmyveins's Avatar
Gasnmyveins
Default 94 AC/ps bracket
I've got the 2 obvious bolts out of it. Can anybody tell me where the hidden ones are? I've got the ps pump unbolted from it, so I can lean it forward. I don't see any bolts that way. I've got both pulleys off, but the tensioner is still on.
Old Nov 3, 2024 | 07:51 PM
Gasnmyveins
This shows places where I have removed the bolts.
Old Nov 3, 2024 | 08:20 PM
Gasnmyveins
I'm not sure if one of the holes in the middle is hiding a bolt.
Old Nov 4, 2024 | 10:41 AM
lt1-xjs's Avatar
lt1-xjs
There is a bolt hidden under the tensioner.
Old Nov 4, 2024 | 01:37 PM
Gasnmyveins
Thanks. I took that off last night, but I didn't see the bolt. However, I have disconnected the ps pump from the bracket, but not from the lines. Maybe that kept me from seeing it.
Now, maybe with that last bolt, I can get the engine out.
Old Nov 4, 2024 | 06:50 PM
Gasnmyveins
Thanks, lt1-xjs!!! You just saved me a lot of aggravation. I would love to know who thought recessing that bolt was a good idea. Granted, if I had removed the ps pump completely, instead of just disconnecting it from the bracket, I would have seen it. But it's still the engineers fault. That's my story, and I'm sticking to it.
Now all I have to do is put my floor jack under the trans, and figure out how to slide the engine forward then up. Should be interesting.
To 94 AC/ps bracket
