Possibly the Starter
Old Nov 5, 2024 | 07:15 PM
carguy65's Avatar
carguy65
Default Possibly the Starter
Drove the C-4 (1993) for two days straight after being parked for a month, there was no problems, but I did notice cold starts were immediate starts, but once driven and warm starting again would drag. Once parked after using for two days I went to start and there was nothing. Dash lights and radio went on like normal but no start not even a clicking sound. I figure it could be the ignition relay, ignition control module or starter, they are all original parts to the 1993 vehicle. Battery is pulling 12.4 V when tested. Any other thoughts
Old Nov 5, 2024 | 07:20 PM
ex-x-fire's Avatar
ex-x-fire
You need to test for power at the little wire of the starter when it's acting up. Most pros used a headlight bulb to test for power, it puts a load on the system whereas a test light could be lit up through weak frayed wires.
