Problem removing radiator shroud.
Old Nov 9, 2024 | 06:09 PM
jgcable's Avatar
jgcable
Default Problem removing radiator shroud.
I have all the bolds and screws off the radiator shroud on my 96 automatic. Shroud is totally loose but I can’t get it off because the AC hardlines on the passenger side are directly in the way. Any tips or tricks will be appreciated. All the videos mention the 3 little screws on each side as being the big problem. I got them all off.
Old Nov 9, 2024 | 07:09 PM
IHBD's Avatar
IHBD
Pro Mechanic
You have to remove the 3 or 4 fasteners across the top that hold the fan housing to the shroud. You don't have to remove the fans.
Lift the driver side of the shroud up first, and you can finagle the tab out from under the a/c lines. You don't have to cut the ear off like some peeps advocate.
An LT1 is not too fussy. An LT5 with the oil cooler lines is much fussier. But it can be done without cutting the ear as well.
Old Nov 9, 2024 | 07:15 PM
fparkin's Avatar
fparkin
Dont know if going pull it to clean it i just put new radiator in my 84 corvette, forty years old lines suck and hard get to a big pain in the ***, heat is your friend.
Old Nov 10, 2024 | 12:46 AM
jgcable's Avatar
jgcable
the front edge of the drivers side of the shroud hangs up on the body. I have been trying to wrestle it up to clear with no success. It appears it will require considerable force
Old Nov 10, 2024 | 02:20 AM
dburgjohn's Avatar
dburgjohn
Did you get the small screws between frame and cover? 7mm I think
Old Nov 10, 2024 | 09:13 AM
Whaleman's Avatar
Whaleman
These are fun to get the first time. Be sure to put them back in the opposite way when putting back together. Dan
Old Nov 10, 2024 | 09:56 AM
jgcable's Avatar
jgcable
every nut, bolt, screw connected to the shroud was removed. I can lift it up. 6 inches on the drivers side but the front edge won’t clear. The passenger side has ac lines running over the shroud flange so obviously it needs to be removed from the drivers side.
Old Nov 10, 2024 | 10:40 AM
jgcable's Avatar
jgcable
[QUOTE=dburgjohn;1608322321]Did you get the small screws between frame and cover? 7mm I think[/
Update…. I went at it again this morning and the shroud came right off and the radiator is out. Now it’s time to shop for a direct fit replacement!
Old Nov 10, 2024 | 10:44 AM
drcook's Avatar
drcook
Finalist 2020 C4 of the Year - Modified
[QUOTE=jgcable;1608322823]
I put a DeWitts in. I would recommend them.
https://www.dewitts.com/collections/...minum-radiator
To Problem removing radiator shroud.
