1988 Bogs on Throttle Application
Old Nov 12, 2024 | 12:13 PM
1988C4Owner's Avatar
1988C4Owner
Default 1988 Bogs on Throttle Application
**[EDIT]** If I ease onto the throttle it will rev, it's just trying to conventionally rev it up that bogs it out.
Hey y'all! My 1988 base coupe now runs and drives! But any application of throttle causes it to bog out, not shut off, but bog and not rev at all. Sometimes I'll get lucky and it'll let me rev it a bit, but more often than not it just bogs. Timing is dialed to 8 0r 10 BTDC (can't for the life of me remember what I actually set it at), fuel pressure is stable in the 40s at idle but I need to check while driving, new pump/sending unit, new IAC/TPS, and new Bosch IIIs. Could low fuel in the tank be a cause of this no-rev nonsense? I know the baffling in these cars is not the best and I wonder if the low fuel level I've kept the car at could be the culprit. Any help would be greatly appreciated, thank you!!
Old Nov 12, 2024 | 01:05 PM
ULTM8Z's Avatar
ULTM8Z
What p/n injectors did you get and who did you get them from? Was it doing this before the injector swap?
I don't think the low fuel level thing is what's causing the problem. A throttle bog occurs too fast for a fuel starvation incident at the fuel tank to impact the pressure in the rails.
Though everytime I hear "Bosch-III", my spider sense starts tingling... lots of ways to get burned by those.
Old Nov 12, 2024 | 01:39 PM
Vets-Vet's Avatar
Vets-Vet
Can you get it to idle and share a Win ALDL screen with us with the "Sensor tab" selected. Any codes now ?? You probably have timing set to 6°. And those darn dial lights, I glued-taped mine to zero so it would not change..
Old Nov 12, 2024 | 02:39 PM
1988C4Owner
Pretty sure they came from SouthBay, but it could've been FIC. Heard they were a good upgrade so I figured while I'm in there. Didn't do this immediately after the install, and didn't do it before. Its relatively recent, wondering if the PROM would need a burn for them or if my TPS/IAC are way off what they need to be. Got a plug for OBD 1 to connect to TunerPro so I'll see what comes of that next time I'm home.
Old Nov 12, 2024 | 02:40 PM
1988C4Owner
She idles fine, I'll try to remember to get a screenshot of TunerPro once I get back from college. No engine codes.
Old Nov 12, 2024 | 03:15 PM
Vets-Vet's Avatar
Vets-Vet
Try and get the screen shot with it idling please.
Donny
Old Nov 12, 2024 | 03:17 PM
ULTM8Z's Avatar
ULTM8Z
When you get the data, export to .csv and post it here.
Old Nov 12, 2024 | 03:46 PM
1988C4Owner
1988C4Owner
Donny
Will do, ought to be home next weekend
Old Nov 12, 2024 | 05:20 PM
tequilaboy's Avatar
tequilaboy
Both MAF and injector pw should directly follow the tps like this: https://datazap.me/u/tequilaboy/ailv...&mark=57-27-42
Old Nov 12, 2024 | 10:11 PM
ULTM8Z's Avatar
ULTM8Z
Can you verify what injectors you got?
Should be a 280XXXXXX number embossed on the side of the injector bodies....
Old Nov 13, 2024 | 12:56 PM
1988C4Owner
I'll have to remember that when I'm home too.
To 1988 Bogs on Throttle Application
